Hey Campy Fans - Teach Me
I just acquired an older (1995?) steel Marinoni frame and will undertake the task of acquiring components to build it. Even though it’s Canadian, I think Campy is more appropriate. I like to find bargains but I also want to use good stuff. I am thinking Centaur or Chorus. But I really am not sure about the different group lines within the Campy brand. Is this basically the same difference as Ultegra to DA where the average person could never tell the difference but the more expensive saves you a few grams? If so, then I don’t care. I can lose a pound or two in a week by laying off the ice cream. But if there is a functional/quality difference then I would like to consider that. Centaur is relatively inexpensive - but, good enough? Do I get anything extra by getting some Chorus?
Also, are there good discount sources for Campy? I got a lot of my Shimano stuff for a song by just watching Performance or Nashbar for sales and using coupons. FYI, this will probably not be my race bike - just a trainer and bike to use on longer rides.
Thanks in advance.
Total Cycling (www.totalcycling.com) in the UK has the cheapest prices I’ve seen anywhere on complete Campy groups. I’m not sure what shipping will end up being to the US, but I think you might still save a bit.
http://www.totalcycling.com/ProductsList/mcs/CategoryID/63/GroupID/2/CatName/Groupsets%20-%20Road/v/3940c454-4fd6-4da0-91ee-6e8326f99e5f
Carbon is the main difference…you get a splash of it here and there with Chorus, most noticeably on the brake levers. I went with it because I felt it would look “cooler”, and we all know how important that is! :wink:
Centaur seems like a great deal (around $750 give or take), and it’s probably what we’ll go with on my wife’s new road bike - because, of course, she’ll never be as “cool” as me…
http://forum.slowtwitch.com/gforum.cgi?post=500940;sb=post_latest_reply;so=ASC;forum_view=forum_view_collapsed;guest=4453257
Take a look and let me know. All you’ll need to come up with are wheels, and I might be able to be convinced to let a set go that came with the bike these parts are off. Please PM or email…my contact info is in my profile.
Centaur should be more than adequate. I probably have 10K miles on an 8 spd Mirage group (The cheapest Campy group, I think you can only get it OEM), so their stuff is quality. The only goofy thing is that Chorus and Record use a different bottom bracket (needs different tool, cranks are not compatible) than Centaur and below. I have Centaur on my P2K.
Bike Nashbar has some good deals. I got a Chorus crankset and bottom bracket for $200.
You also may want to check the rear dropout spacing. Circa 1995 was 7 or 8 spd, with new 10 spd rear dropouts are a bit wider. Not as big a deal with a steel frame, since it usually has a bit more give than carbon or Aluminum.
Good luck, you are obviously a smart man if you are building a bike with Campy.
Centaur is great - unless you are looking for lighter components or carbon bling there is really no reason to go with Chorus or Record.
I have run Centaur on my road bike and tri bike, currently run record/chorus on my road bike. Can’t say enough good things about it.
Hunt around and see if you can get some of the old Chorus single pivot brakes. Those brakes are a work of art.
My road bike has the old Daytona, now called Centaur, and it works great. Very durable too, never had a problem. The Chorus has a definite cooler look, especially with the carbon brake levers/shifters :slight_smile:
Congrats for choosing Campagnolo, you’ll never go back! :wink: Just say (Shima)NO!
I’ve got Daytona/Centaur on 2 bikes and Chorus on another. Honestly I can’t tell a significant difference. The shifting may be a bit crisper on the Chorus, but for $50-100 more, I can live with Centaur. The internals of the shifters are virtually identical if you were to look at the drawings for the parts. I seem to actually get more miles out of the Centaur bottom brackets, plus you can get them dirt cheap ($20 or so). I typically get those at www.lickbike.com or sometimes totalcycling.
By the way, some would consider Centaur as just a notch below Ultegra. Definitely a quality group.
SAC, I just KNEW you had to be a (fellow) Campy guy.
Even Veloce, aside from the crank, is pretty nice.
I ride with a Veloce rear der… flawless :slight_smile:
Centaur or Veloce will be perfect for what your training bike. Great thing about campy is that is durable and small parts can be replaced. I am currently changing out my old 8 speed record group for a 10 speed chorus. Thing is the 8 speed still works perfectly even though it is starting to look beat up. I will save it to build a rainy day bike.
Centaur is good stuff.
are you setting it up as a road bike or a tri bike?
i ask because i’ve just switched to a centaur set-up, and there’s really only one thing i don’t like about it.
it sounds crazy, but the hoods are really annoying. it’s the first time i’ve ever given any thought to the material that the hoods are made out of, but the shimano stuff i had before on my old bike kept its grip when my hands were sweaty… the hoods on my centaur ergo shifters get really slippery once i start sweating, which is usually pretty early into the ride. so standing on hills and holding onto the hoods isn’t an option, or at least not a good one.
so, if you’re doing it as a road bike, check the material of the hoods…
of course, all this could well just be my own idiosyncrecies.
I’d have to agree, as compared to Shimano hoods, Campy hoods (at least those on my Chorus) are definintely “slippery-er.”
Take the brake hoods off, then use some of the cloth electrical tape and put this on (wrap it) before you put your hoods back on. I had this same problem and this cured it. You might have to coat the hoods in alcohol to get them back on.
Campy hoods become less slippery over time.
not anymore. The BB tool is the same for Centuar now.
The Centuar alloy crank is lighter than the Chorus one.
Mirage is not OEM only. It can be bought aftermarket and Xenon is below Mirage and can sell for as little as $429 for a complete group!
8 speed rear end has always been 130mm old, It would be very rare to find a 126mm 7 speed bike made in teh mid90s.
good luck,
-SD
Just about everything camp makes will get better with time.
Campy → breaks in
Shimano → wears out
exactly - have it on all my bikes except my MTB.
