Help with new toys please
Stopped at Tom D’s this morning to pick up two things I needed to make my new bike more fun to ride, aerobottle, and computer “knob” mount. However, there does not seem to be enough room on my aero bars for both. Anybody else run into this? If so, how did you solve it? Or am I just not seeing something obvious. The stats: Carbon stryke aero bar on a Cervelo Dual with a Jetstream bottle and the standard “knob”
Jim
Thank you once again for the coffee and sparing me the indignation of visitng Starbuck’s as well as the attendant abuse from the Barristas.
Mount the knob on the stem and put the bottle in it’s normal place. Ooooh. I think I need a bit of polishing…
Thankee
Ok, that didn’t work, I can get the knob on the stem but then the computer won’t fit on the knob. It hits the end of my aero bars.
Jim
last year, I had profile aerolite bars. I mounted the knob on the outside left bar. aerobottle fit perfectly between the bars and the computer was on the outside. With arms extended on the bars, I just had to turn my forearm out to read the computer.
replace your brain with the computer. Problem solved.
Thanks got it figured out a bit ago now I don’t know if I like it. Well I guess I will learn to. No place else to put it except the top tube, which I did consider.
If I did that, would I then think logically?
Put your knob on the upward part of your aerobars. About halfway between the bend and the shifters, obviously inboard. Many of the guys I ride with have theirs where I described. I also have a heart rate monitor, so I put both on the outboard left side on a minoura space grip, so that kept them away from the aero bottle.
----->Trent
Run the knob on the inside of your aerobars. On the outside, your hand would obscure it, for certain.
Meat Polisher’s idea was great if the stem were long enough, as I ran a few computers the way he described it.
Jim, bunnyman is completely right about putting the computer on the outside. While this does work quite well for me, the computer is obscured by my arms. I use the profile aerodrink and since I only look at the computer every so often, I thought it was an OK sacrifice. You may not agree. I was not able to but the computer on the upward bend of the aerobars because I like using bar tape on those sections.
If I put the knob anywhere on the inside of the aerobar* *I am unable to remove the aero bottle. I ended up with it on the outside and fairly far down on the bars. I do have to shift my arm slightly to see it. I will ride like this for a while and see how it goes.
If you don’t super tighten the stub that attaches to your aero bar on which you mount your computer, you can just twist the entire unit up. I turn it up to insert the drink bottle. I turn it back down to use it… As a bonus it helps secure the drink bottle. No straps or rubber band needed. Works great.
