Help with bar tape >:|
Visual learner here:
I’ve scanned the web and haven’t come across a good visual tutorial for wrapping bar tape. It’s my Achilles heel in bike maintenance. After a couple rides, I’m continually left to fix this problem:
http://i11.tinypic.com/2r5e2wx.jpg
Suggestions.
I did my first bar tape job this weekend.
The first couple times I got your result.
Then I took my time and pulled the tape tighter as I wrapped and over-lapped the tape more.
It worked out a lot better and didn’t leave gaps.
You need more overlap in that area and you need to make sure it is TIGHT!!!
http://www.parktool.com/repair/readhowto.asp?id=71
Poor guy…that looks terrible.
It looks like foam-tape, which “unravels” and becomes untensioned rather easy. Try cork or Fizik’s tape. The drops look good, but after the lever you’ll need to overlap A LOT more to accomodate the bend to the flats.
The link to Park is excellent. Personally, I reverse tape…
tape is too loose!..s t r e t c h i t man!
As Ken suggested, try the Park Tool site. It’s actually an outstanding site with an absolute TON of information about bike maitenance. Required reading for all the DIY folks.
However, your problem is one of the reasons I like old-school round bars - it’s way easier to wrap the bar tape!
I mentioned this on another post before but I will make the same suggestion to you as well. I doubt you have any tape left over but if you do take about a 2" section of it and hold each end with each hand and slowly pull on the tape until you break it! In order to tape bars correctly you have to have a feel for how much you can yank on the tape and how hard you can without it breaking. It looks like you are just too scared to really crank on the tape and get good tension. Try my trick and you will see - it works and you will know how hard you can pull.
Another vote here for the park tool website, even I can do my own tape job without messing it up following their instructions.
I am just re-looking at this picture. What bars are those? I can’t tell from the picture. It’s up to you, but some of the new funky carbon bars with the flat sections on the tops where not intended to have bar tape on them. The wrapping is meant to go to the crook of the bars only where it curves up to horizontal. If you look at pictures of the few pro riders who ride these bars(I note that it seems the old-school all round bars still seem to be the bar of choice of many top pro roadies), the tape stops just as the bars curve to horizontal. That’s not to say, that you can’t do this - just that it may be more challenging to do.
