Help: Severe numbness in feet while cycling
Hello guys this is the main issue right now for me in terms of comfort while riding . I get numb feets that usually gets to pain in the area while riding, I can’t even feel my toes at some points. It happend after about 20-30 and is usually way worst in my right foot. I’m using time pedals which seem to have cleats with a large surface area. This is really affecting my training since I don’t feel my feet while going out for the run.So far this is what I have done alleviate the problem:
-Adjust seat height
-Move cleat position all over the foot/shoe = no improvement
-Changed to shorter cleat bolts
-Use insoles
-Changed shoes and in diferent size
-Try diferent pedals {spd’s} with no luck
WHAT’S NEXT?
that´s familiar for me. the harder I ride, the colder it is, the more it is certain that my toes go numb. but it doesn´t really bother me, my toes get working again as soon as I start running. It´s something with the circulation in the feet, but anyway you don´t really need the muscles in your toes when cycling.
I had this problem, what made it better was wider shoes (geniusmega) AND orthotics with a metatarsal pad. It was still happening (I had bunions) but it helped a lot.
You also need to rule out a lower back issue with numbness in both feet. Most likely a pressure/shoe/cleat problem. One more thing, are you a “masher”?
i had the same problem and found cycling without socks helped…i eventually had to get new bikes shoes and now i do not have the problem anymore, so maybe its your shoes! maybe you need to try another brand even though you did try new shoes…good luck!
Ditto on all of the above. Changing my seat position and height a bit helped some, but I found that about every 15-20 minutes after I have had someting to eat/drink I would get out of the saddle for about 20 seconds and get blood flowing again and I do this as soon as the ride starts. I also get out of the saddle some after I have accelerated down a hill and coast. Hope it all helps.
Friends have been telling me I’m a masher.
I had the same problem. Switched to wider, longer shoes and put in the black Superfeet insoles, which supposedly are designed for skates and such. Problem solved. I think the wider shoes made the biggest difference, in my case.
I’m using pretty wide louis garneau shoes right now, don’t know how WIDER shoes would help more. Also why does my left foot feels less uncomfortable?
Wider shoe helps because if the shoe is too narrow, the digital nerves get compressed. Try an insole with a met pad and work on sticking the dorsum of your foot to the top of the shoe and “pulling” some on your pedal stroke versus alsways “mashing” down. I dont know how to explain, maybe someone can reexplain what I am trying to say:-)
My LBS set me up with a pair of Shimano R085 shoes, which apparently are wider than most other shoes. They aren’t super high-end shoes, but they don’t make my feet numb and work great in my case. Which shoe fits best is presumbaly personal to your feet. Maybe try a few different pairs at a shop. But the R085 model is definitely a wider option than what I had before…
Wifey had the same issue, she got a bike fit, and changed out the saddle. The seat was too far back and in combination with a saddle that was too wide, the position ended up decreasing blood flow to the feet. She did also get Super Feet insoles. Problem solved, no more numb feet. You may want to look into a new saddle if yours is old & the padding has mashed down some. It’d be like riding on a 2 x 4 & that is bound to make more than just your feet numb.
