Help Pick a Frame
I had my measurements taken yesterday and was hoping the shop would be able to narrow down frame choices for me but they really didn’t. They pretty much told me I can get any bike with a 52-55 top tube and that I have short legs for my torso and arms (call me stumpy?). Given the following measurements can you suggest a frame based on my size? Many thanks in advance.
http://i12.tinypic.com/2ivkyaa.jpg
Would you go for a larger frame with a shorter stem or a smaller frame with a longer stem?
Ok Stumpy, did they give you any suggestions for saddle-bar drop, saddle - bar distance or the like?
Otherwise all that can really be said is the P-X (on slowtwitch deal) or QR (Lucero/Caliente/Seduza are same frame so could use any of them) are the best value
my $.02
shorter top tube w/ longer (110-120) stem for better handling
given the limited supplied #'s, i’d say 56.8 TT with a 120 stem
edit: i’m really suprised they didn’t give you your femur/thigh length. that would really help…
No suggestions for saddle-bar drop or saddle-bar distance. I’m more flexible than the average guy and am hoping to get as aggressive position as possible. The PX and QR do seem like good values. QR has the 77 degree seat tube.
80.9 inseam? I hope that isn’t measured in inches.
Have you ridden these frames? Buy the one that feels right. Who gives a F what the ST panel thinks.
I know they’re not on your list but you’re actually quite a strong candidate for a cervelo or felt. They have steep STA and are long and low. With good flexibility and a long trunk this is the kind of design you are looking for, plus they are the narrowest bikes and thus arguably the most aero.
That suggestion only complicates your decision but it’s definitely worth considering (unless you are set on buying from that particular store).
That store only carries Lemond tri bikes so I’m ordering online, I’m not set on anything. I’ve thought of the P2 but it has either a 53 Top tube with a 12 head tube or 54.5 top tube and 14 head tube, Those don’t seem that low. The P3 is a little pricey.
Thanks for the suggestion. I’ll look at those again.
The Planet X with the aerobars is a great deal. PM me if you have questions.
Ric
take a cm off the HT measurements for cervelo - the high bb makes it effectively shorter. also the steeper STA makes the TT look shorter
