Help on sizing comparison felt b2 to transition
I fit pretty well on a large transition, but the geo is listed as vert and horizontal distance from BB, is there a simple way to equate that to felt dimensions on their geo chart? the specialized had vision trimax bars on a 110 stem and if i was not carefull i’d just hit my knee on the pad when standing–not enough to loose control but annoying
so i am considering 120 stem on a 56, but would need to trim the extensions. the saddle tip was at about 2 cm behind BB center, and i felt like i wanted to go back a cm (probably for the knee to pad issue).
in most road bikes i ride a 56 with 110 stem and the saddle tip is 7cm behind the bb
thanks
jim
From the ST Stack/Reach page:http://www.slowtwitch.com/stackreach.html#Anchor-FELT
Size L Transition: Stack 52.6 Reach 40.5
Felt B2 Frame size 54 Stack 51.0 Reach 41.5
56 52.5 42.5
58 54.5 45.0
So, based on this, you would probably use a 56 B2 with a stem that is 2cm shorter than your current one on the Transition.
aweseome thanks for the link and taking the time to help me out!
jim
