Thursday whilst I was trying to improve the system rating on my laptop via the System details on the cotnrol panel I appear to have increased the size of the display. Now I have a large print version! I have tried going through all the various tasks that I can find such as optimize visual display on change resolution but don’t seem to be able to get back to normal.
I am loathe to reset to all the defualts in case I lose some of my preferences. Where do I go to get back to normal size please? Maybe I am just choosing apply when I need OK or something similarly obvious.
Thanks for any help you can offer.
go to Control panel>Display>Display Prop.>Setting(screen resoultion).
I have mine set at 1024 by 768 to fill up the screen .Yours maybe different but i think this is what you are talking about.
No, it’s not that. I have it on the highest resolution (as it was before the change occurred) and it’s still large. Some buttons like the latest news and view coupons on this page have the their text slightly blurred.
I have also selected the Windows help and support which seems to agree that the settings I have are the best for an LCD screen suxh as my laptop has. I have also looked at reducing the DPI but the only visible option is to increase it for the visually impaired! I need to reduce it despite this window showing it set at the smaller standard default.
Try the control key and the - (minus sign) key at the same time.
Hey PG, that worked! I notice I had to do that to the hotmail window separately too. Is that a permanent reset or will I have to do that each time I log on or restart my laptop?
Should be permanent. If you ever want to make it big again, just use the control and the plus key, and yeah, each window and each tab in the window is separate. My computer is super sensitive to some secret key stroke I manage to do all the time, and it’s constantly changing the font size on me.
Just turned back on, and everything is fine. Thanks Maggs, me 'earty!
Good luck with the 7th pound!
