Help! Need a route from Seal Bch to C'bad
All my fellow So Cal ST’ers, I need your help. If I can avoid some of the major traffic, signals, etc. that would be best. I do not know where the entrance onto Pendleton is for example. Thanks!
PCH the whole way, except for Camp Pendleton.
Search posts for “Pendleton” and you’ll find a few discussions of the route:
http://forum.slowtwitch.com/gforum.cgi?do=search_results&search_forum=all&search_string=pendleton&search_type=AND&search_fields=sb&search_time=&search_user_username=&sb=score&mh=50
http://forum.slowtwitch.com/gforum.cgi?post=859116;search_string=pendleton;guest=10591590#859116
The entrance to Camp Pendleton can be accessed by getting on the bike path at the south end of San Clemente. Stay on PCH through town and where it makes a 90 degree left to go over I-5 (Christanitos (sp) Road), the bike path entrance is on the right just before the overpass. It is marked and there will be numerous surfer’s cars parked in the area. The bike path will take you through San Onofre State Park after about a mile on a surface street. Technically, you will be in Camp Pendleton as soon as you go through the gate at the end of the park, but the guard shack is after passing through the 2nd gate (about 2 miles) and taking a left under I-5 and going about 1/4 mile.
Dean Wilson
www.anaerobiczone.com
Just make sure you have a photo id to get thru CAmp Pendleton.
If you really want to avoid the lights, then take the fwy around Pendelton. It’s one of the only spots that you can use it legally, and you just fly the 7 miles or so. Kind of hairy with all the big trucks going 70mph right next to you, but the lane is wide, just watch for debris…
as others have said, PCH all the way, except for Camp Pendleton. Also, make sure that you use new tires and have good pressure in them. Otherwise the chances of a getting a flat by riding through Long Beach are well, kind of 90%.
Entrance onto Pendleton is easy to find. Once you pass under the bridge you take an immediate right. The road is a little “bumpy” for a bit. You then have about a mile of nice pavement before another half mile of bumpy surface. Then there will be a gate and usually there are some cars parked on the south side of the gate. Take a LEFT there and a 200m later you have to show your ID to get into Camp Pendleton.
On camp, make sure you follow the signs. Not very difficult at all. You never go far inland and pretty much stay parallel to the Freeway.
Awesome guys! Thanks for the help. I have ridden on base, but only from the O’side entrance. Hope to see some of you guys out there along the way
