Help mounting forerunner on p2sl
HELP! I just ordered the quick release kit for my 305, and realized that on my cervelo p2sl there is no horizontal bar for the base to connect too. Has anyone been able to mount there garmin on the aerobars???
Get a short section of PVC pipe and run it between the aerobar extension (secure it with a couple of zip ties) If you want to get fancy, then notch the ends and paint the pipe to match your bars.
Here is what I did…but note, after about 500miles with this setup, the Garmin flew off and is now at the Garmin factory being fixed…I think you need to still tape the unit down for safety:
http://giambrone.info/stuff/305_kit.htm
