Help Me Run
When I run it wuld seem I throw my leg out sideways, I don’t notice it when I run but I do it and I am worried it could be the cause of current/future injuries.
What can I do to fix this, I try to concentrate on pushing the leg back but I guess it does not work. Tight hammies? Calves? hips?
the imgae would not insert but it is here: http://bp0.blogger.com/_06UzzDKue88/Rbz7p5qfcvI/AAAAAAAAAAM/NdasI-ec9dQ/s1600-h/pioneer+8k+3.jpg
“throwing it out” in swing phase points to a tight muscle group (usually posterior and/or lateral). You have not had an injury before? It sure looks like you would land pretty pronated (you should land supinated, then pronate through midstance before re-supination at toe off). One would expect some medial ankle, arch or medial knee pain. A short video would be far more helpful than a static image.
I currently have a burning pain throughout the backs of my knees (I think you helped with testing ideas). It has been there months but I don’t think it is related. But who knows. I actually get the burning increased when I ride my bike.
I have very little flexibility in the hamstrings right now. Do you think this could be the cause? I will try and get video ofme running soon, I may post somevideo of me on both my bikes in the trainer today to see about the other issues.
thanks
B
Not sure if this will help but here is a quick vid…
http://www.youtube.com/watch?v=nde3RRFokEQ
Its pretty grain and not in the middle of a race when things really break down
Have you tried working on some drills? High knees; butt-kickers; strides; etc. should all help your running form.
Also might consider finding a local running group or coach and getting some live and real-time feedback.
Sorry, only see about 2 secs front and back (need a side view). But, from the rear, you are pronated pretty bad throughout midstance with an early heel off indicating a tight calf and/or hamstrings. Also a pretty heavy heel striker (but it also looks somewhat downhill on the way back). Now, a heavy heel striker is not in itself a bad thing (as so many make it out to be) and I’d need to see a side view running to correlate this. You also seem like a pretty big guy (no offense meant). You would do well in a heavy duty motion control shoe for now. I’m not a huge fan of them, but they exist for a reason. The main problem with them is their very high heel stack. They certainly help your subtalar joint/foot pronation and instability, but tend to “force” more of a heel strike as well. I think you can instinctively tell you are tight in the calf/hamstrings. If you have not had any significant injuries though, I wouldn’t be too concerned about radically changing your stride. However, if you start doing some decent mileage (say 45-60 miles/week), you may start having some issues, which I think is what you are trying to avoid.
thanks for your help…last question on this thread I promise.
I had some motion control shoes previous but they made me run on the outsides of my feet and it hurt a lot.
What stretches/exercises can I do to concentrate on calf/hamstring flexibilty and get them nice and loose.
I will see what I can in a day or 2 with regards to a side view.
By the way no offense taken, I am 215 or so not too big but big for a distance guy.
I tend to run into this same movement when I have old worn shoes. It causes the toe end of my foot to point to the side slightly. I think it starts when my heel strikes the ground. It strikes somewhat overpronated on the heel end, then forces my foot to open to the side thru out the foot strike on the ground, making the toe end come out of the strike pointed to the outside of you stride.
It kind of creates the motion of running diagonally across the shoe instead of inline with the shoe!
If I run for some time past the life of my shoes, my inside knee begins to hurt a bit because of the pointing of the toe outward while running distances.
Sit in a chair and pick up your leg and turn your toe outward, then return it to the normal position. This is the motion my foot goes thru. It’s most noticeable on the leg pick up coming out of the backstride like in the picture.
Just my thoughts! Something to think about.
S-Back…
thanks for the info.
in my case these are totally new shoes, total of maybe 50k on them.
maybe I ran in my old shoes for so long that I developed a style unto itself and kept it
B
