Assuming a 22mm Conti Attack (22mm Schwalbe Ironman for the tubular) at let’s call it 22-24mph in most triathlon conditions:
Flo 30Enve 45 (45mm V-shaped rim)Zipp 303 FirecrestZipp 404 Pre-Firecrest tubularFlo 90
My assumption is that the Flo 90 (or zipp 808/Aeolus 9/Enve 8.9) would be measurably faster and the rest would all be in the same ballpark.
That would about be my ranking. The rolling resistance difference between the 404s and the rest could come into play on low wind days. I seem to remember about a 3 watt difference between the Attacks and that tubular. This does also assume a good glue job on the tubular.
DUDE! You just got a 303FC! Ride that thing! Seriously, it’s a great wheel… I just got tired of swapping break pads
Also, keep in mind that the Schwalbe Ironman Tubular is probably just a bit faster than the Attack. Just remembered I have to call the shop and ask what type of glue they used.
Ok so the 303 FC is a tub and has a Schwalbe Ironman glued to it.
That change anything? These new fast tubulars (zipp) have me wanting to switch back from clinchers. Used tubular wheels are practically free right now!
