Hey man, there’s a few other options regarding the hubs/wheels…
You can pick up a cheap hub like a deore or something (assuming that you’re using shimano) and then hit the local shop to order/give you a 105 axle. Now, i don’t have the shimano spec sheet right here, so this exact combo might work, but the idea is that you simply need to respace a 130mm mtb. hub to 135mm using a road axle. Very easily done. In addition, consult the above manufactures, but quite often cross framesets will be spaced to 132.5 mm’s so that you can use either 135 or 130mm hubs.
In regards to prebuilt wheels, there is another sol’n as well. Mavic speed city’s are pretty nice for cross, but again I wouldn’t ride a prebuilt for your smashing bike.
I’ll throw my hat into the redline ring…in addition to being a killer deal, its also got excellent geometry, which is often the bane of what could otherwise be a nice cross bike. Just watch out for the seriously hardcore stuff like no water bottle bosses, which is useless for anything other than pure racing.
In an unrelated matter, i once tried to ride my cross bike up a tree when i had a mighty large amount of a malted BEvERage in me. It was a large oak tree with big roots that had a lovely radius of curverature, closely matching a 700c wheel. So i got a head of steam, and opted for the drops cause i’m a hammer. I big ringed it right into that bugger, and up i went…
I hit about 45 degree angle, and my front wheel slipped, i came down like Meatloaf on the front end of my jake.
The next morning i figured I’d have a flat GL330 on the front of my bike, but all i’d done was tear the glue off the underside of the tire. Rock on tubulars.
The moral of the story, beer, wet trees, and campy equiped cross bikes don’t mix.
