Help me increase my bike cadence
When I first started riding I had no idea what I was doing. I would have it in the hardest gear I could push and would do hill repeats to build strength like that.
When I joined TNT (o no…an evil purple jersey wearer) and had a coach teach me about higher cadence I was very uncomfortable at first. Felt the same bouncy feeling.
Just keep doing it til you get used to it. Like many other problems, easily fixed by more time on the saddle
counting for 15 seconds and multiple by 4 is not that hard either :slight_smile:
Fred.
thanks for the input everyone. the problem i’m facing is that at a higher cadence, i start to wobble. i can do a higher cadence, but then it feels like i’m gonna fall off the side of the bike. i’m just not stable when i start to get up to 80+. i didn’t know if this might be a bike fit thing, or maybe a core strength issue, or maybe even a flexibility issue (i’m probably the most unflexible person that i know…) pcsronbo had a good point about learning to “spin in circles”. i think i mainly push down left, push down right, push down left, etc…
i’ve always been a slow grinder. i can push the smaller gears and maintain some decent speed on the flats. but then my legs are always fried for the run. i thought that maybe if i could spin at an easier gear, i could maintain the speed without burning my legs out so much. but, i can’t ride the easier gears, because spinning causes me to wobble on top of the bike and it’s very unstable.
Yep- sounds like a combination of fitting, saddle may be too high(as was said above) and your technique- try pulling up instead of pushing down- also- 1 leg drills on a trainer will help- your cadence should improve very quickly. I was having problems a while ago- finally, did a training ride in the smallest gearing I had- was banging about 125-130 rpms for 40 minutes-1 hr, makes 90 seems very easy after that. You won’t go fast, but the turnover is there. Good luck.
I guess I’ll remain the voice of dissention amongst most. True, for many trained, experienced cyclists/triathletes there are some telling signs that your seat may be too high, bad position, etc. However, I would bet that putting your bike on a trainer a couple of times per week (even if you only start for 5 minutes) and cranking up your cadence (so you don’t have to worry about actually falling over) well educate your muscles to fire in shorter response times. I’ve seen this over and over again with new people who get into the sport, and working with these types of folks. It simply is based on lack of previous muscle adaptation.
With that said, someone did mention it is a function of power. Without getting too much into training with power, you will notice that the faster you are riding, the more likely that the “I feel like I’m going to fall over” feeling will disappear. Heck, if you are worried about falling over, just trying shifting to increase your cadence beyond your control on downhills only for awhile (again - you won’t have to worry about falling over). It’s the same as running downhill to increase leg turnover. It takes practice, but you’ll get there.
In my opinion riding at high cadence is mostly related to two things. Experience (time in the saddle) and excellent pedaling coordination. Time in the saddle can only be fixed by one thing. Coordination can be best worked on by two things, either a fixie or PowerCranks. PowerCranks is better than a fixie for this purpose but a fixie is the next best thing.
Just think if Lance A came around earlier (or later) Jan would probably have won the tour 6 times. Everyone would be saying “You gotta spin a big gear like Jan does to go fast” and we would all be pedaling slow and powerful.
The thread titles would be like “Help me decrease my bike cadence”
jaretj
