Help me build my ultimate strength program
My off season is coming up. Swimming is by far my weakness and will get added time in the neighborhood of 6x a week. Before doign tri’s I hurt my shoulder lifting and ti has been fine since except for every once and a while on big swim days i get some soreness/pain. I have good balance between muscles and dont really have a weak muscle. My goals are to make my shoulders bombproof to aid int he extra swimming and to get stronger overall. I will do 3 core workouts during the week. That leave 2 45 minute workouts for the weightroom. I was thinking maybe the first day do all core lifts like squat, bench, deadlift, etc. Then the second day indiviual muscles with an emphsis on shoulders. I dont have time for a lot of lifts so I am not sure if this would even work well. Any thoughts?
your wasting your time on this forum…it is nothing but triathletes interested in only getting a T- shirt from the race. Most of them don’t have time for weights.
IMO use a 75/25 mix of upper to lower body weight machines. Do 3 sets of 10 on each machine. Should be able to do 12-17 weight machines in an hour.
I would look into exercises that strengthen the rotator muscles. These routines would use stretch cords and involve high reps. Not really your typical strength routine. I will also be looking to improve my upper body strength but will add these exercises as well. It may alleve the discomfort in the sholders for you.
Curls. Lots of 'em. Of the 12 oz. variety. Repeat until you pass out. Wake up, then start from the beginning. It’s done wonders for me. In fact, it’s helped me talk in choppy sentences :wink:
K
Should I add them to both days or just one day. Let me put ti a better way, should I do the same workout focusing on core lifts and shoulders or shoudl I do core one day then other lifts the next witha a focus on shoulders?
I’d recommend doing stability stuff such as pushups on a ball (not your own of course),
If you’re going to do benchpress and shoulder presses (or similar excercises) keep the weights light - don’t try any “maximum strength - 3-5 rep” sets. Do at least 8-10 reps and never go to failure. I’ve hurt my shoulders several times lifting and also have had chronic rotator cuff issues when I don’t take care of it.
Right now I bench solely for appearance sake - I don’t seriously expect it to help my swimming and neither should you. Doesn’t mean you shouldn’t do it though, but don’t risk hurting yourself by doing too much weight.
elund is right on with the rotator cuff excersises. Somenoe posted this recently - it should fit your needs perfectly
http://www.usaswimming.org/USASWeb/ViewMiscArticle.aspx?TabId=445&Alias=Rainbow&Lang=en-US&mid=700&ItemId=700
These should be easy enough to do every day, or at least every other day if time is an issue.
Great link you have just been elivated to god like status for the evening enjoy it. That should solve my shoulder prblem, now if you could teach me to swim… The reason why I am gonna bench is it is not only the best chest lift but also uses tri’s, back and shoulders. It is a core lift.
First the shoulder stability. I’m no pt, but I’ve looked into this for my own well being in the past. Here are a couple I’ve liked:
  • I’m a big fan of l-flys(light weight, no more than 10lbs), in the 10 rep range.
  • Standing rows. Use a cable machine, or better yet a light jump stretch band. Hook it around something nose hight and pull, squeezing your lats keeping your forearms about shoulder height and parallel to the ground.
  • Here’s an article by Mike Mahler. He’s a big fan of clubbells for shoulder stabilization.
    http://www.bodybuilding.com/fun/mahler42.htm
  • Of course, when you’re tired of working on the supporting muscles, focus on military press for ulitmate shoulder strength.
Second, your overall routine. Given your time constraint, it sounds like a PTP-style routine(see Pavel’s articles at www.dragondoor.com) mixed with some of the aforementioned joint stabilization excercises would be perfect. I’d just pick two or three big lifts like you said, squat, deadlift, bench/overheard press, weighted pullups/dips, etc… and do them 3-5 sets/3-5 reps with 3-5 minute breaks both days. Switch excercises every 3-4 weeks or whenever you feel yourself plateauing.
Have fun.
check out crossfit.com has some good “total fitness” type of routines (they are into a lot of body weight type stuff). I would stay away from the 3 x 8-10 rep routine , your just working the same fibers every set. Go higher in the rep count (20) and mix in some supersets to work all of that muscle group fibers. Back in the gym days we used to perform a month block of 1x20 rep set per exercise to MMF (momentary muscular failure). Failing at 16, hold the weight, squeeze out a couple more, hold ect ect until 20 reps are completed. Much more effective than the 3x8 rep count.
cbass.com has some good information as well.
Don’t forget the ultimate routine “The Tabata Protocol” you should be able to google it for additional info. Only if you like to visit Mr Pukey.
Tabata Squats:
8x20 seconds with 10 seconds rest between rounds, as many squats (no weight) (arms folded over chest) as you can perform for 8 rounds. Tally the number of squats for each round. Go to Crossfit.com click on “exercises” then download “Tabata Squat” video.
It took a week for my legs to recover from my first 8 rounds with a total of 2 minutes and 40 seconds of work. Amazing stuff!!!
Info from a website:
2.) Aggressive Strength Tip Of The Week
Increase Cardio and burn more fat in less time with “The Tabata Protocol”
Recently, Dr. Tabata in Japan did a study in which he documented the
benefits of high intensity aerobic training. Dr Tabata found that a
protocol of 20 seconds of all out cardio followed by 10 seconds of
moderate cardio for a total of four minutes was just as effective as
forty-five minutes of moderate cardio. In addition, the Tabata Protocol
increased anaerobic conditioning as well while moderate cardio only
enhances aerobic capacity. Thus, the good news is that you do not have to
waste a lot of time doing boring forms of cardio to get into great shape.
You can choose instead to step it up a notch apply the Tabata Protocol to
your training a few times a week.
There are many forms of cardio that the Tabata Protocol can be applied to.
You can use an exercise bike, treadmill, or cross trainer. However, there
is another option that I really like. I call this option the Tabata Heavy
Bag Workout. Here is how it works, go all out for twenty seconds on a
heavy bag followed by ten seconds of jumping in place. Then go all out
again on the heavy bag for twenty seconds again. Go back and forth eight
times for a total of four minutes. Work up to twenty minutes 2-3 times a
week and your will be in incredible shape.
Be creative with the Tabata Protocol as the possibilities are endless. If
your primary goal is fat loss, then apply the Tabata Protocol three times
a week. Otherwise, two times a week will get the job done.
Me again… Disclaimer:
I do not make the claim that weight training in any way will improve your triathlon performance! So get off my back SAC. :wink:
bitwiz is your god - I am but his messenger.
I’m also the worst swimmer I know.
Good luck to you.
Here are a couple articles that will help
http://www.slowtwitch.com/mainheadings/coachcorn/strength.html
http://www.slowtwitch.com/mainheadings/coachcorn/strength2.html
and I would suggest doing all resistance training in the same day which would probably translate to 2-3 days per week total. If you are truly doing “core lifts” then all body parts will be used, and, if you try additional work the following day on a certain area such as the shoulders, they would be better off having the recovery time. Do the supplemental work after the core lift, same day. The article talks about that as well.
Good luck
“IMO use a 75/25 mix of upper to lower body weight machines.”
For any kind of sports fitness, machines are usually NFG, because all the exercises are totally stabilized and way too isolated. Free weight, cable/stretch cords and body weight exercises are best.
Deadlifts, push-ups, and pull-ups will deliver crazy strength gains. Whether or not these are core exercises for you depends on your interpretation and realization of alignment. Push-ups and pull-ups can eventually be done every day of the week if your will so desires, but when starting back up after a layoff be courteous to your muscles and don’t impose excessive amounts of acute trauma. With deadlifts I would start out doing them several times a week, at intensities that will not cause much trauma. Within about six to eight weeks, for me, I’ll pull deads only once a week because by then I’m ready for extreme intensities, and anything less feels like I’m just stretching out. All three of these exercises have the potential to really thrash your shoulders, which should make it obvious that if you truly want “ultimate strength” you absolutely have to take care of your shoulders.
lifting is good but you need to learn a proper stroke to avoid injuring your shoulder. Get someone to watch you and fix whatever is screwy.
http://www.exercisedb.com/
select the muscle you wanna work and you will find here pilates, strentching and workouts for it.
NOS, If you want to learn to swim here is my yreccomendation. (Disclaimer, I have been seriously swimming for only 2 years but here is what I did) Find a Masters program. Swimming is too hard to learn on your own. You need a coach watching you. If I recall(we chatted about Mustangs, I am about to put my convertible Cobra away for the winter) you are in Fla. Here is a link to start your search for a Masters Program.
http://www.usms.org/placswim/placswimform.php?LMSCID=14
Try to get some 1 on 1 coaching. It will be worth it.
el
we did chat about stangs, I still have you on my buddy list. I have been to a masters program and while it was good the coach didnt give to much attention to drills or form. Also there was a good amount of other strokes being done. I have a friend who swam that is gonna help me and I am starting a new job as a sub teacher so i look ot make friends with the swim coaches at the different schools. My stang has been sitting for a few months now. It became too fast for the street. I cant drive it in rain, cold or traffic. Plus at 8 miles to the gallon and 93 octane a must i cant afford it.
