Help me appease the flat-tire gods! How have I wronged them?
After driving 45 minutes to the only uninterrupted, relatively flat trail I could find to do a time trial for my coach, I began warming up. Got far enough away from the car, picked up some speed, and was headed down a small hill when I felt that odd, sickening change of handling in my bike and said to myself - don’t even tell me! Sure enough, another puncture flat.
This is my fourth or fifth puncture flat on this bike in the last 2 months or so. It seems like every 50-75 miles I get a new one. Yesterday, after I pulled over to fix it, I couldn’t find the culprit but I found the hole. Somewhat near the tire valve. I patched it up, started using the stupid hand pump, and snapped off the presta valve end. That was all I could take, and I rode back to my car seething with about 40 psi in the front tire.
Some more information: I ride a Serotta CXII. Pretty sure this doesn’t matter but there you have it. The wheels are Mavic 650s. They probably still have less than 1000 miles on them and are less than a year old. They appear close to true. The tires are Michelin Pro Race 650x23 clinchers. The inside of the tires looks clean - no obvious debris. The offending tubes are just Performance generic brand, although the first offending tube was a much better quality. I live in the California Bay Area and ride mainly on roads, but for the most part the roads seem fairly free of debris. The wheels have Fond du Jante rim tape and it looks intact. No spokes are sticking up or anything like that. I have never punctured the rear tire. Original tube still intact.
And now, several questions: What did I do to anger the flat tire gods? How can I appease them? I promise that I am a “nice” bike rider generally. I’ve heard anecdotally now that the 650 Michelins are unusually puncture-prone. Anyone else hear this? Are there better tubes out there on which the valves don’t snap in half? (not the first time this has happened) - oh, and the floor pump can slide on and off of them without wrestling it off? My rear tube is the original and it’s much easier to get the pump on and off. CO2 cartridges. I think it’s time to start experimenting given my problems with flats and snapping off valves. And the fact that I can’t see how I would ever have muscled the frame pump up to 116 psi. Any recommendations here?
Thank you all for your advice!
you’re still using a hand pump?
okay, i can’t answer your question but i too went through a streak of flat tires recently. i think a lot of it was me riding in the dark (early morning) and running over sharp shit i couldn’t see. the lbs recommended a kendra kevlar tire and so far so good. i also changed brands of my tubes (figured it couldn’t hurt).
  1. Does the rim tape installed cover everything? You don’t want any of those little “nipple” holes showing. They can cause pinch flats too.
  2. Have you checked this inside and out of the tire and the rim? Run your thumb around in there Make sure there isn’t anything even remotely sharp or obtrusive sticking out.
  3. Are you opposed to switching tires? I always had the worst luck with a certain pair of Continental’s I got tired of switching tubes every third ride, so I went with a cheaper (yet more durable tire) and I haven’t had problems on that bike since.
clearly the reason you got these flats is bike fit.
Never had so many flat tires! Come to think of it, before this setup, never had a flat tire! I’m not a very big person either so I guess I can get away with a lot. Obviously, now that I have, I see the folly!
What are you running for tire pressure? When I first started riding I had a string of flats until a wrench pointed out that I was only running about 95-100 psi and needed to run 110+ at least. Presto no more flats.
Darn. I knew I was too comfortable and fast.
Is your rimstrip that plastic mavic rim strip?
That crap should be illigal to sell.
Otherwise, get some heavy duty tubes, some 25mm synthetic chord tires, velox rimstrip, and ride at 100 psi.
I rode about 5,000 miles and 18 months on Continental Ultra Gatorskins without a flat last year. They are tough.
Check the tire (very closely) for any cuts. Even a tiny cut will allow the tube to herniate and eventually blow. I have seen a couple tires that had small cuts in the sidewall that led to frequent failures, some even before the wheel was back on the bike.
"clearly the reason you got these flats is bike fit. "
And you’re not riding a Cervelo…
I had one experience during an Alcatraz race years ago where I got not one, not two, but three flats in the space of a half-mile. It was the year (this was an Envirosports version of the race) someone had strewn tacks and or nails across the road somewhere in the Presidio, and for whatever reason I didn’t flat until the base of the hill going back up past the Cliff House…the first tube I put in I guess I rushed because I pinched it; the second tube I put in probably popped because of the same thing, I don’t know…but what a nightmare!
