Help....Magura RT6 TT brakes (P5 brakes) broken, need spare part
The adjusting bolt on my P5 brakes has broken, does anyone know where I can get a replacement?
You won’t find any,slim chance if you contact Magura USA.
I use these brakes and have back up parts from eBay.
There is a used set of RT6 on eBay for 199.00 I would jump on it if I were you
Are you talking about the bolt in the brake lever? Did it actually brake or just crossthread?
Yes that’s the one. Broke.
No idea where to get one from. Rather get a bolt than a new brake set if I can.
Any idea ?
Any idea ?
I think you’re really screwed on this one. More so than even with the other parts. I found this online.
https://www.tehava.com/Perfion/File.aspx?id=30e3c889-a754-4d9a-a3ed-d893d8990934
It doesn’t look like that part was even a separate part at any point. Even when you could order parts.
I have a new complete set that have never been used. Levers and brakes. I had purchased them to see if we could integrate them back a few years ago. I think it may also have come with some bleed kit. If someone needs a complete set just contact me and we can work out a cost.
I’ve got a bunch of mixed RT6/RT8 TT brake lever parts since I had to buy a full set for a similar problem. PM me and I might be able to hook you up with the bolt you need
Hello Indianacyclist,
Do you still have spare parts for the RT6 TT brakes? I managed to break the safety lever and need to replace it.
Kind Regards,
Gerd
