Help: How to pace OLY run part
Looking for some insight on how to pace the run section of an Olympic Triathlon.
Take the first mile at 98-99% effort then settle into anticipated pace?
Take the first two miles all out and then slow up and hold whatever until the end?
Whoah!!!
First, I need to ask what you mean by 98-99%?
the truth is that the fastest way to race the distance, barring something unforeseen happening out there (suddenly tipping over the dehydration point, reaching glycogen depletion, tripping…or just being unable to tolerate the mental demands) is to run even or slightly negative splits.
To do that you need one of two things:
  1. know from experience what you can run that 10k in and break that down in to a per mile pace and do not exceed that pace in the first mile. Then continue to hold it…but the sensation will be one of ever so gradually accelerating when all you are really doing is maintaining.
OR
  1. Have so many years of solid running/racing experience under your belt that you know from perceived effort what the sustainable pace feels like. And trust me, it will feel very, very much slower than you would self-select if you are not very experienced.
Let’s say you can run that 10k in a triathlon at 49:30 (about 8min/mile pace). Your first mile should be right around 8:00 perhaps a little bit slower allowing for a slower first quarter mile due to transition. Will that 8:00 mile feel 98%? Not at all, it will feel too easy. But maintaining that pace all the way to the finish would be 98%…that’s why I don’t know what you mean by going out at 98%.
Back to our little scenario here…if you can run that 49:30 10k, but just barely, you can expect to feel actually quite comfortable during the first few miles. About at the 5k mark you are becoming uncomfortable, but not the kind of discomfort that screams ‘STOP!’…but it builds to that point and that’s how you should feel during the last mile. When you finish, you should get passed by a few people during the last 100meters because they didn’t pace properly and you did…you would have been much farther behind those people if you hadn’t paced right, so let them go. (or don’t if you have it in you!)
Hope that helped.
So “always” run it evenly paced.
And if your racing right, you should be 30-60 seconds within your stand alone 10K time? If not, likely biking too hard.
Yes and no - you need to take into account other factors such as what time the race goes off, outside temp, your race experience, etc…
Usually here in FL most running races are in the late winter\early spring so I can’t say I am going to be 30 seconds off a 10K when the temp and humidity can be significantly different. Also as I have done more tri’s my run times have come much closer to my stand alone times.
Pretty much always run it evenly, unless you want to build with negative splits…that used to work best for me but it takes incredible discipline to run what feels like too easy, having my coaches and friends yelling at me because they think I’m being lazy, and actually never giving in to the increasing pain throughout the run…but running people down is awesome!
but don’t forget that terrain will vary the pace for you…it’s the effort you keep steady.
The only time I’d suggest varying the pace is when you are head to head with the leaders (or whomever your personal goal is to beat) then you can play pace changes against them to break them…but since you are doing a lot of distance work with little speed work right now training for IM that might not be good for you to try at this point.
How fast you can run the 10k compared to your standalone time depends on personal factors and not the least of which is the bike pacing that you have chosen which may be part of your tactics. It’s an altogether different question as to which will get you to the finish sooner, a very hard ride with a survival run, or an easier ride with a stronger run. It probably depends mostly on your bike training.
I looked at your blog after posting. Do you have any of your mile splits during that 10k?
Based on your 10k time in that tri, and assuming you could do slightly faster than that with great pacing/weather/training/diet/taper, I would say that you want a 6:00 first mile (maybe as slow as 6:20 if you run your first quarter mile slower after biking). Try to hold that 6:00 pace all the way through. You may not be able to, but it’s close enough to your average to be a smart pace.
If that race I see in your blog had something silly like a 5:30 or faster first mile, then I do think that 6:00 could be obtained as an average.
The only good pace is a suicide pace…
x2
You go at just below vomitting pace until you are about 1/2 mile from the finish when you pick it bit by bit depending on whether your competition is nearby until you are going as fast as possible by the finish. Also, you always have about a 12-second sprint left in you at the end no matter how bad you feel.
I think you need to rethink the term 98-99%, you can’t run a whole mile at 98-99%, unless your definition of 100% is way way off.
Ditto on the even to slightly negative split.
You’ll be surprised who you catch as you stay steady and
others fade. If you really have anything left in the last 1-2
miles, there’s your negative split. The other guys ahead of you
weren’t meant to be caught.
Good luck
