Help buying wood stove
i need a wood stove. this is very closely related to triathlon. you’ll just have to take my word for it.
i need to know, from people who REALLY know, where is the best value for me in a free standing wood stove? anybody know anybody in the biz?
mid sized, maybe 40,000 to 60,000 btu. don’t talk to me about pellet stoves, coal stoves, gas stoves, fireplace inserts. just wood stoves.
I know nothing about this, but I will be pleased to sit by yours when you get it.
Dan,
 I've been using the Vermont Castings Federal Convection Heater since 1991 in my Upstate NY house.  Unlike a radiant woodstove, this one is convection with a fan.  The fan just about doubles heat output.  It also has a catalitic burner which is like free heat since it burns the combustibles in the smoke before it gets to the flue.  Since I get all my wood from trees that fall in the forest, it's all free heat.  I have to take down about twelve trees around my house. Now that they are branching out, they are getting too close.  More free heat!  This is my primary heat source.  I have electric or back up and my bills are $45 a month year round.
These days the Quadrafire stoves are very popular.  In fact as soon as I can find the time, I'm going to put on and addition with a Quadrafire pellet stove at the other end of the house.   Oh yeah, you don't want to hear about pellet stoves, but I'm looking forword to slowing down on the woodstove and keeping the pellet stove going full time.
http://im1.shutterfly.com/procserv/47b5df07b3127cce9f7f45e92c6200000016108IcMnDluzby
Dan, Here is what I know which isn’t alot. We have a place up by the Volcano and use a Jotul cause they sell them in Hilo. It is a tad smaller at about 30k. It is a nice rig and heats our shanty up pretty well. Some of the real houses up there use a couple of them as they have more control as to what part of the house stays warmer and when.
My brother in law in Montana has a Vermont casting one that he got at a barn sale that must be 50 years old and heats up his huge basement. Not sure what the others are rated but I would bet theirs is around 80k. There is another one that looks nice from BC Canada called Northwest stoves. I saw them in a stove shop in Missoula last fall when I went to see my folks. I would guess there are a number of stove people in Cali that could help and the Mother Earth News probably has some major research on which are better. I would bet they are all around $2k ish in price for a big unit and depends if you want a fancy one with enamel and brass or a cast iron colored one.
If it was me I would look hard at the Vermont Casting or Jotul. Aloha G
I lived in Virginia for 20 years. For 12 of those I heated my 2,800 sq ft house with a Cunningham. The house was 3 levels. We had the stove in the basement. The laundry shute helped move the heat up to the other floors. It was big enough that I only loaded it every 36 to 40 hours with wood. It had a heat activated damper, ash pan (so you don’t need to scoop ashes out of the fire box) and took logs about 15 inches in diameter and about 20 inches long.
Dan,
Very good question, one that my girlfriend and I have been starting to research as well. We want a wood burning stove in our new house as a primary source of heat, (trying to “get off the grid” as much as possible). We haven’t come to much of a decision yet, so I’m glad you asked this. I’m sure someone out in slowtwitchia must have some knowledge.
I can’t live to far from you. Nothern NY.I near the river (St. Lwerence). I have no electric and heat with just wood. I have a Lopi stove. Works great and has a glass in the door to see the fire. We had -32f this week nice and warm inside.Easy on wood to.It,s warming to 30 this weekend time to get the bike out :wink:
The Dirt
www.Jotulflame.com
I have a close friend that works with them in portland maine and can personally attest to the effectiveness of the jotul’s in -60 temps.
Kevin
I’m guessing that you want to heat the water in the Endless Pool. If I"m right just get what ever will hook up to you water heater.
I grew up in houses that are still heated w/ wood stoves.
If you’re looking to just heat w/ the stove, I recommend you get a tiled stove. You can get them just about any shape you want. They are made of massive shaped ceramic tiles (to increase surface area). Nice thing is that they retain heat for about 12 hours. This means that the room is still warm in the am after you let the fire go out at night, and that it’s easier to start a new fire b/c there’s good air circulation in there.
If you’re using it for cooking AND heating, you want to get a flat-top iron stove. They have a big flat iron/steel surface (about 2 X 4 feet) which gets heated from a wood fire below. The one my parents still use has a wood drawer below for kindling, an oven, and a hot water basin which humidifies the room nicely although the original purpose is to have hot water for cleaning I believe. It is a GREAT thing to have when it’s cold. If you want I can figure out what the manufacturer is. They’re pretty popular where I am from, and geared twds fuel efficiency.
these are contemporary and very efficient. check out the link below.
http://www.raiswittus.com/
If you want the best look very effiecient and consistent heat try a woodstock soapstone wood stove.
http://www.woodstove.com/
I worked for Lopi about eighteen years ago and compiled information on Lopi’s competitors. The brands mentioned are quality products. To expand a little on Brian 286’s comments:
A little undersized is good because these stoves run best, and cleanest at full throttle; fire box size… bigger the box the bigger the fuel, less time cutting firewood and less likely to break the glass in the door when you slam the doors shut;
glass doors, I know that Lopi had an airwash that would keep the glass clean… several of their competitors have similar features;
doors, double doors are lighter, not putting as much weight on the hinges and don’t swing out as far into the room;
and last, refractories, I like the fire brick better becuase it’s easier to replace as opposed to the one piece cast panels that have to be replaced as a unit.
I heated my house for 15 years with an Lopi Answer Premier. It was the dust, dirt, grit, and ash that made me get rid of it.
Jay
Dan, If you are indeed heating water for your endless pool, check out Snorkelstove.com. These all aluminum babies are made for hot tubs; all that sticks out of the water is the opening that accepts the wood and the exhaust pipe. Works great.
