Help buying a stem
I’ve made a dozen phone calls and cannot find an ITM Millenium Adjustable stem (100mm) in stock anywhere. I can’t wait 3 weeks for shipment.
Anybody got any tips for me on where to find one of these babies?
Try Ribble (www.ribblecycles.co.uk) or one of the other UK shops. They list ITM adjustable, don’t know if its in stock or not though.
bump
Julian, this is a funny part to need in a hurry. I am guessing you are experimenting with position. that sucker will add half a pound to your bike.
I can lend you a 10 cm Ritchey stem if that helps. I also have an 11 cm ITM Millenium. Let me know if they help.
Actually, it’s replacing a Look Ergostem that weighs 200+ grams more than the ITM. I’ve got the Look all tweaked to how I want it, and it turns out the final position is exactly suited for the ITM. It’s too steep of a drop for a fixed stem. The ITM pointed down as far as it will go will suit me just right (I’m 90% sure). I bought a big-ish frame so that it has a long wheelbase, but that means I need to have the stem pointing down pretty far.
Another problem with the Look is that, in the configuration I have it, my Profile water bottle won’t sit snug between the bars.
You have a 110 ITM adjustable?
No Julian, sorry. 11 cm fixed.
Good luck with your search.
