Oh, I should have added- A unique factor to an endurance race that is 10-17 hours in duration are the set of variables presented by environmental conditions.
Specifically, humidity, temperature, wind, etc. These variables have an enormous impact on your optimal nutrition plan.
an example is the '04 Ironman New Zealand. The temperature at race start was in the 50’s with extremely cold water temperatures due to glacial run-off and the opening of a dam that fed the lake we swam in.
The extreme cold in the morning and early on the bike, through thick fog at low temperatures, caused an increased requirement for calories to help maintain body temperature. In an odd paradox, the challenge in the first three hours of the race was to avoid hypothermia- a cold weather malidy. Wet, cold and lightly dressed in wet clothing on the bike when it was very humid and cool I froze my butt off.
Later in the afternoon the sun came out, the temperature climbed to the upper 70’s I believe and the race organization had removed one aid station from the course- effectively removing four aid staions since it was a double out-and-back marathon. As a result, low sodium levels and dehydration as well as hyperthermia became a concern.
I lost 11 pounds in that race and wound up in the medical tent for 2-3 hours and felt really bad the next day.
If my nutrition paln had been more adaptive to the environmental conditions I could have saved 30-45 minutes. My run pace on the 2nd segment of the run was 8:30 per mile. When the efffects of dehydration started to take their toll I slowed to 10:00 per mile, slower than I had been on any long training run. If I had worn a Fuel Belt with extra hydration I may have been able to go faster.
My Point: Your nutrition plan has to be flexible to the environmental conditions, and you need to do research on the environmental trends for the race area you are doing to help determine the viability of your nutrition plan, and understand what changes need to be made in the event the weather changes.
If you look at National Weather Service records for the area surrounding Ironman Wisconsin, you see that since weather records have been kept for that region there are wild swings in environmental conditions.
From a historical perspective only, the possibility of everything form high humidity and temps in the high 90’s (2003 race conditions at IMMoo) to 40’s and rain exist. Those are wildly different conditions with wildly different nutritional requirements. That has be a factor in your nutrition plan and testing during training.
Weather intel over the race area is a key peice of the puzzle in crafting your nutrition plan.
