Help! Advice for piriformis injury pls
So I’ve been hobbling around for a couple of months now. Doing PT, stretching, core work, etc. with minimal improvement. Already had to cancel my A race (1/2 IM) because I haven’t been able to run for a long time and now the rest of my season seems in jeopardy. I’m frustrated.
Anyone out there have experience with this type of injury? Prognosis? Expected healing time? Should I get an MRI or X-ray to rule out other causes?
Checked out Doug Stern’s website and think I’ll try his aquarunning program. Hope this helps as I’m getting pretty grumpy without running.
Thanks for the help.
robert
What type of piriformis injury (bruise, strain, chronic or acute)? Who/what type Dr. gave the diagnosis? How did he/she arrive at this (if they told you)? What have you tried… meds, stretches, exercises? What started all of this? Any sciatic (leg pain, numbness, tingling) symptoms? What makes it worse, better???
What have the PT’s done and has it been effective, or how effective?
X-ray probably wouldn’t show you anything, MRI might be OK. Depends on a lot of stuff.
Why don’t you PM me with this stuff and I’ll help give you some questions/treatment options to take to the PT, chiro, etc…
Lehmkuhler
PM’d you. Thanks
robert
Anyone else with advice or experience?
Robert…
I am sure Lehmkuhler (sp?) will be able to give you plenty of advice, but wanted to chime in with personal experience of piriformis syndrome. First time it went out treatment was considerably longer, but each time I found what worked and recovery goes quicker.
====this is way long but wanted you to have some background of what to expect. If it isn’t serious, take it serious. If it is serious, take as much downtime as possible. Watch ALL positions that might aggravate it from climbing hills on the bike to even sex, and long distance driving without a break (or any combos there of).
I am VERY biased as for treatment. PT, Chiro and Massage is the combo that helps to keep my problem workable. Usually only if I am running on uneven surfaces (cobblestones usually set it off), overworking/fatigue, poor nutrition/stress triggers the cascade of problems. Get to the root of your problem and at least get it stabilized if you can.
Good news…Ironically my ITB holds up just fine, but my Piriformis first goes out followed by the peroneus muscles and then over contracted psoas major which ultimately creates dropped foot. FIX the piriformis now and don’t push through it. Whoever checks you out look for imbalances on the other side of the body (all the way up to the neck and down to the other toe). Muscles work in a cross pattern kind of way so look at your opposite neck and shoulder from the butt for problems. When my neck is out, my piriformis often seizes up. DO NOT SLACK ON RECOVERY!!! If you do you will leave way too much scar tissue and the next time will be even worse.
What worked:
Immediately during the events often a butt massage and stretches. IF a chiropractor is available I have them adjust my hip.
After event aggressive Chiropractic treatment including usually Electrical Muscle Stim to the butt (NOT pleasurable at all!!!). I have the luxury of getting adjusted as needed and find 3xs/week for 2 weeks usually is all I need to set the pelvis back to mobility.
Strengthening work includes one leg squats and step ups with flexion (utilizing a step bench). Once stability is re-attained (traditionally 2-3 week recovery from injury for me–worse case was a whole season until I figured out what kept pulling it) I up strength training and increase stretching. Depending on how bad the piriformis is injured, often I have to start out with balancing on one foot then move up to an uneven surface for balancing. Good PT can set up a program. I wouldn’t try it on my own.
Off season…I ramp up slowly. Watch my posture, and stretch daily. ICE my aggravated SI Joint on the involved Piriformis side after every run/long ride. Manual massage on the entire muscle and deep etching along the whole sacrum and greater trochanter -origin and insertion of piriformis–oh so enjoyable. If I feel it is going to catch–I skip all impact activity and stretch out in the pool for a few hours with only pulls.
ARNICA has truly helped my sore muscles and especially the bruising that is inevitable from the friction work on the glute.
As for X-rays…depends on what they are looking for. X-rays helped to show how off skew my hips were, but it won’t show you the muscle. Biased speaking, my hip X-rays were taken while standing versus laying down. I didn’t need an MRI to tell me how messed up my piriformis was, however had I not gotten better MRI was on the horizon to make sure everything was ok.
Hope you get yours fixed. If you have any questions feel free to PM me.
Eileen,
Wow - thanks for all the helpful info. I will certainly take it easy. This is my first bout with piriformis problems but it likely stems from my chronic low back / pelvic tilt issues. Taking it slow seems to be the general consensus then strengthening the supporting muscles to prevent future flare-ups.
My PT has suggested taking it easy with massage for a while and I haven’t tried chiropractic yet so those are two more options that I can pursue.
What is ARNICA?
Thanks a bunch,
robert
Arnica is a topical OTC cream you can use. I have a patient who has Chronic fatigue and she takes an internal capsule. I usually massage her with either Arnica cream/lotion/oil whichever I have on me. It amazes me how much it causes her bruises to clear up quickly. No clue how/why it works. Any local health food place would have it. BIOTONE massage cream comes with arnica and ivy extracts, along with a few other creams. If your PT is working on you topically ask if they can use Arnica…or if you can bring it into them and have them strip the piriformis with cross fiber friction work. I am trying to think of the product line from Australlia that has the richest arnica I have found yet…sorry, drawing a blank.
Biased speaking…chiropractic usually can help with pelvic integrity and low back problems. Ask around for someone reputable in your area. ART practitioner will incorporate a little bit of everything. With massage==GENTLE first, then gradually build. Don’t take all that can be dished, the area is injured treat it as such!
Don’t rush the recovery. When you get back to volume stage, go gradually at first.
