Assuming that I have never crashed my helmet, how long will it last? I knwo that some materials get brittle after a while and I was unsure if this was a problem with today’s helmets.
I’ve heard that you should never keep a helmet more than three years. Once it has been crashed or dropped hard; straight in the garbage or, if you’re one of those strange ducks, on your trophy shelf.
5 years is recommended for casual use. If used heavily sooner. UV does a lot of unseen damage to a helmet as does sweat. If the black foam inside is all white, smushed and crusty, I would say get a new one.
Helmets are a very important piece of equipment, if you are unsure of it replace it. This also gives you the opportunity to get a new one, “It doesn’t match my new kit/bike, or I’m so bored of this colour I want another.”
When you do dispose of your helmet do it properly DESTROY it. Take the hammer to it, cut the straps. This way it will not be plucked out of the garbage and used unknowingly be someone else thinking that it is fine.
I have never replaced the pads in my helmets, I will just replace the helmet.
Excellent question. It never occured to me that there would be a life span / built in obsolesence associated with a helmet. I own three helmets. I choose the helmet depending on what bike I’m riding (Cross-UVEX mtn, road-Gyro or TT/Du-UVEX Aero). I spend only two or three hours on the bike per week.
Does that mean my helmets will last longer than someone who only has one since I can only sweat in one helmet at a time?
Will my helmet last longer because of less UV exposure than other riders?
Will my helmet last longer because of less time used than other riders?
Is there something on a helmet manufacturers website that addresses the longevity of their helmets (i.e. how often they need to be replaced)?
In the big picture, the helmet is a vey inexpensive part of the cost of Tri/Du. It is to say the least, a very important part of my safety on the bike. I will not compromise my safety for a few $$$, but I am curious to get some answers to your question & mine.
UV rays and sweat only aid in the deterioration of your helmet relative to time. It’s like the thread on running shoes and shelf life.
To better visualize what time does and how your helmet can breakdown, just think of those old styrofoam cups you see on the side of the road. The styrofoam pellets have started to seperate, but structurally it still appears to be able to hold water. So compared to a new cup, the old cup will break at a lower pressure. Granted your helmet is a lot denser, but the same thing will happen to your helmet.
Here is the FAQ straight from Bell’s website:
HOW DO I CARE FOR/CLEAN MY HELMET?
Cleaning Helmets
Helmets are made of materials that can be damaged by many common cleaners. Petroleum-based solvents or cleaners are especially dangerous. For best results, clean the helmet using a soft cloth or sponge, warm water and mild dish soap. Salt build-up on straps is best removed using a sponge and water.
Lice
Do not use a spray of any type. Place the helmet into an airtight plastic bag for 48 hours. Then, discard the pads and use a soft cloth or sponge, warm water and mild soap to clean the surface. Safely discard the plastic bag and replace the pads (you can call us for replacement pads).
Storing Helmets
Excessive heat can damage the helmet (Heat damaged helmets will appear to have uneven or bubbly surfaces). After each use allow the helmet to air dry and then store in a cool, dry place.
Painting and Stickering Helmets
We strongly advise against painting, stickering or otherwise modifying a helmet because all of these things can damage the helmet and/or reduce it’s protective capabilities.
WHEN SHOULD I REPLACE MY HELMET?
How often should a helmet be replaced under normal wear and tear?
Bell has a general recommendation of replacing a helmet every three (3) years. If you have any questions as to the condition of your helmet please call us for information or to set up a free inspection.
