Folks. My rear HED3 is way out of true both sideways (1/4 inch) and radially (1/8 inch). So it has a bit of a flat spot as well as a lateral wobble. I know HED can fix the wobble but what about the flat spot? Not sure if it happened on a pot hole or what. Thanks, Graham
That’s really unusual. The thing should come out the mold round.The sideways issue could be as a result of the bearings needing changed or tightened.
If it’s a new wheel I’d send it back and get another. I doubt the radial issue can be solved.
