HED3 experts need help, long
Last summer my new HED3 more or less blew up. IT was wobbling so bad after a few rides I sent it back. They sent the wheel back to me and it was worse and almost hitting the frame after the first 20 mile ride on it ( I actually bailed on the ride it was so bad and had to be picked up). Sooooooo they sent me another wheel. Since this was at the end of summer and I was riding my road bike and not the P2C I only rode the P2C down my block and hung it up until this past week with the newly sent HED3 on it. It on this short ride mad no noise (half a block).
Yesterday I rode the P2C on the trainer for 2 hrs. pretty much the whole time it sounded like a person drumming on the frame with a hammer. The more pressure put to the bike while spining the worse (louder) it got. Any gear would produce the noise. Big ring little ring all of them. When I would power brake the rear while it really sound like constant popping. It did the same tonight as well right from the start for an hour.
After the hour was over I could leave the bike in the 39x11 and hand turn the cranks with my ear to the seat down tube and it is very loud there (popping). I took the wheel off and removed the thin spacer from the cassette body and put the cassette back on and torqued and the cassette was very loose with the nut at torque spec. So I reinstalled the thin shim and put the HED back on. Still no change noise still there. I put another wheel on (rolf vector) with a 12x25 cassette on it and the noise is gone. Nothing from the down tube when hand turning it or clipped in.
So next I took the 11X23 off the HED and put it on the Rolf and the 12X25 on the HED and now nether wheel makes a noise at this time. Power braking it spining hard the noise is gone with ether wheel on. This is the Dura Ace derailure and Ultegra chain 10spd.
Is it possible this cassette is not getting tight enough on the HED because of a faulty clearance on the cassette body for this to happen? Could the machining on the teeth be off enought that with a the carbon HED for it to carry the hoise through the carbon bike frame and the noise is asorbed on the spoked Rolf.
The one thing I did not try was to double the shims from both cassettes and then see if the 11X23 would make noise on the HED.
Anyone hear of this or deal with a similar problem? Any help would be great.
Has anyone seen a faulty cassette before? IT is all shimano and both cassettes have less than 500 miles on them.
You need a different spacer.
yeah, different spacer or take it to a shop to check out, preferrably one that sells H3s and even better one that has an employee that rides H3s…
I had a similar problem with a set of HED3s that were pretty old…I replaced the hub body twice…a new spacer might help, I would keep calling HED. Their customer service is pretty good, and they want to make stuff right…I am under the opinion that if you sent your wheel back to them, it should come back a LOT better. They are pretty nice up there in minnesota and will help you out…There is a guy named Dino that I spoke with a couple of times who was really cool…
Anyway, I had my H3s for 8 years and they are tough wheels…My wife(best wife in the world) bought me a set of 999s for my b-day last year because i just switched to a 700c bike. Hopefully I will have good success with them.
Justin
So you have elimated the wheel itself as the problem. It’s the way that one particular cassette fits the hub that seeems to be causing the racket. Others have said it - try a larger spacer with the noisey cassette. The spacer that comes with Mavic wheels is very thick - try one of those.
