Could some of you please measure the distance between the extensions on your HED integrated bar? I would like to upgrade to this bar, and I want to know if the revolution hydration system will fit.
Thanks,
-Colin
Thanks,
-Colin
The width is adjustable. It depends on what works for you. The hydration system you are speaking of should work with the bar no problem. You need to figure out whether or the width needed to make the hydration system fit is comfortable for you.
I know this is not the answer you were looking for, but it is an important point to consider. I wish I could give you a better answer than that. Maybe Tom D. can give you a better explanation.
I can give you all the measurements you want…but as above, they are adjustable.
If there is one issue I have with the Heds:
I’d like the the extensions to be closer while allowing the pads to be wider. In an effort to find the best compromise, my extensions face slightly “inward” to allow my hands to be closer/elbows wider.
Thanks guys. I knew that the HEDs were very adjustable, but I didn’t know that you could adjust the width of the extensions.
Word,
-C
Sounds like we have the same issue. I have mine set up the same way. The only downside is that I can’t use my Profile Aero Drink Bottle because of this. I really like have a bottle right there but I don’t know what to do. Any suggestions?
i built a carbon fiber shelf/aero bottle mount for my HED bars. Works much better than the Profile mount/duct tape I was using before. I have to put those pictures up, sorry never get around to it.
How exactly did you build that? Would love to see those pics when you get time.
I must be an idiot… where do you get carbon fiber from to do these things?
