HED s-bend question
I recently purchased a set of HED aerobars with the s-bend extensions. I am very impressed with the relative adjustability as compared to my previous Easton Attack bars. Since I am new to the S-bend extensions, my question has to do with the fit. Presuming I am “dialed in” with regards to the other aspects of my bike fit (ie- stem length, saddle position, etc…), should the bar end shifters be just beyond my hands when I am “in the position” so that I need to reach a bit to shift or closer? I realize it is in part personal preference, I just don’t want to cut off the ends only to regret this later once I get used to the extensions. Thanks for your input.
imho, I would leave them alone–if you have to “reach just a bit to shift”. I cut mine down, and although they fit fine, I miss the extra length, and the bit of extra maneuverability.
regards, roddw
I run my own aluminium double butted straights and I have my shifters about 1 inch longer than the y probably should be. The reason i left it as it gives you more option to stretch out or just change position as your body settles/fatigues within a race. Be cautious - measure twice, cut once !!!
FWIW -
I originally bought the Hed integrated to get my hoods similiar with my road bike while retaining my same aero position (Something that can not be accomplised on my old Carbon Xs). It got me close, but not exactly what I thought.
Why? Mainly b/c the sweet spot of the arm rest is on the “fattest” portion of my forearm.
So…in my case, I’m running a 60cm stem b/c this puts everything in the right place, minus the “drops” being just a tad too short.
As for the shifter position, I chopped everything off the front end of the S that I could while still being able fit the shifter. (This is tough b/c of the slight bend).
With the arm rest in position and the “front” of the shifter set…it’s just a matter of getting the proper length, which can vary based upon where you are most using the S.
If I need more length in the future, I’ll simply use a longer stem.
I guess what I’m really trying to say is that my original purposes of buying the bar (hood position) didn’t exactly become a reality b/c there are other measurement worth considering. Still better than the Carbon X though!
BE CAREFUL if you decide to trim the shifter end of your S-Bends. You need enough ‘straight’ tube for the bar end shifters to mount flush. I trimmed mine down too much and the bar end shifters could not be inserted fully due to the bend in the bars. Oh well, another lesson learned the hard way…
We fit the carbon S-bends on my bike in November, and struggled with the ideal length. Steve Hed said that you do cut them down (warning us about cutting from the front) so we cut a good 4 cm from the back, and 1 from the front. My chief concern was having to change my position to shift, which defeats the purpose of Bar-end shifters, and being as aero as possible.
Don’t be afraid to cut (from the back!). Put yourself in a good position on the bike then mark where your hands rest comfortably. Cut about 1cm above where your thumb/forefinger rest–but make that cut is from the back after measuring, or else you won’t be able to use them.
Or take it to a bike fitter and let them do it. I don’t cut carbon…I cut cheese.
This is an interesting topic. I just began tinkering with mine yesterday. A meager 15 mins of trainer time and my forearms were getting tired. I think this is because the s-bend is too shallow if you are using spacers below your armpads. Whoops.
I also found that I prefer the bars to point inward a bit toward the front.
Where can I find deeper s-bends (i.e., to get the bend up higher)? Someone mentioned ATB bars.
Aztec,
we have 2 bends, taller and shorter. As you have found out, you really want the taller ones if you are using risers under your armrests. Alloy are in stock, both normal and tall, carbon: 3-4 week backlog for either. -Andy (at Hed wheels)
FWIW -
Did you move the pads to the rear position? This will move them back a good way and might allow you to use a longer stem to get the hood position you were looking for, while retaining the pad position you require. Just remove the pad and rotate it 180 degrees and bold back on.
Very good point. They are in the forward position. If I put them in the rear position with a longer stem, I would dramatically have to cut the extensions (carbon) side that fit into the bar. Definately an option and would mostly likely get me in the hood/aero position I originally wanted. The thought of cutting more $80 carbon ext, screwing it up, and then waiting for months to replace is perhaps my limiter.
Just goes to show these bars are VERY adjustable…
I’m running the pads in the rear position now, and encountered limits to how far I could cut the aluminum s-bends down. I ended up about 1cm longer than I wanted, but your comment got me thinking. Now I might consider drilling a new set of mounting holes in the pads and moving them forward. Then I could shorten the stem a bit more to bring the extensions back that last cm.
