I have been using an OP 32 spoke yellow cap PT pro with a wheel cover for time-trialing this season and like it very much. It is a pretty heavy wheel and lacks the fancy carbon bulge. I am thinking of buying a HED jet tubular Powertap disc for my Cervelo p3sl. Any experience with this setup. How will the jet disc fit between the chain stays? Is there more room with the aluminum version p3 than the carbon?
You should be fine. The current Jet C2 Disc is working with the Cervelo’s just fine. Plus, Hed will build Powertap set-ups. Call Pauly or Timmer at Hed and they can get you set-up.
You won’t have a problem with a P3SL. The clearance will be tight on a P3C, but since the rim is as stiff as a spoked wheel, you don’t have to worry about flexing it into the chainstays or pads.
HED is going to send my LBS a cardboard sizing wheel to address this issue. I am interested to see what this looks like.
