I’m currently using a DT swiss wheel with a Powertap hub for all my training. I crashed last year and knocked the wheel out of true and when they trued it they said the rim was slightly bent but they were able to true it and it has been fine for the last few months (granted I havn’t ridden that much). I am doing my first IM this summer so I was contemplating having the wheel fixed before the IM (IMLP) just to be sure it is solid. I also just bought a HED jet 60 for the front wheel to race with and it looks quite bombproof. I race with a wheelcover and was planning on doing that again this year. But with the DT swiss rim damaged I was contemplating buying a Jet 90 for the rear wheel and having my Powertap built into that wheel. Only problem is that I would be training on that wheel full time and racing on it as well. Any reason to not do this? Anyone train full time on a HED Jet wheel? I would like to eliminate having to put on and take off the wheelcover as well… it does get a bit annoying putting it on and removing it, but it also rubs on my rear deraileur in the largest cassette ring, and I cannot get it to stop rubbing regardless of what I do with the limiter screw.
I run a jet 90 on the front as a race wheel, but I also use once in awhile in training and I am 210lbs. I have never had any issues with it, still very true.
What would have happened to that Jet 90 if it was on your bike when you crashed last year? Are you prepared to take that risk?
Don’t do it. Trust me, I know.
If your wheel cover rubs your derailleur, the cover needs to be trimmed (it’s too big and bulges out). Don’t change the trim on your derailleur to address that issue.
Why pay extra for the Jet 90 and then just use a wheel cover? Why not just use the cover on a standard Alu wheel with PT?
If i were to get the Jet 90 with my PT I would ditch the wheelcover and just use the jet 90. I like the wheelcover in theory and like it’s performance, but I don’t like putting it on and taking it off… it is fairly easy and I spend hours cleaning and lubing my bike before each race so it shouldn’t matter… but I still don’t like doing that part for some reason.
