Hi… I am having problems getting these clip-ons setup. I am trying to get just the right amount of resistence on the armrests so they flip up easily and stay in place. Mine are either really loose, or really tight and don’t want to move. I think there is a certain torque each bolt needs to be tightened to, as well as doing it in a paricular order to get it just right. I managed to get it right on one so far, but struggling with the others. Any tips on getting this done? Any help is appreciated!
Put a “spring washer” where the bolt passes through the cup mount. Both sides.
You can put a bit more bend in the washers than they come with. I bent them a tad more and it worked out great. I have two pairs of these aerobars. I would adjust the top bolt and bottom bolt(s) equal as much as possible until the clamps are snug and them tighten down the top bolt all the way. Tighten the bottom bolts to the desired torque specs and you should be fine.
