I just received the HED Clip Lite’s and the left bar is very loose. I have the bolt torqued to HED’s specs. The right bar fit’s perfectly, could the left bar be out of spec? Thanks.
Could be out of spec, but that does seem odd. You may double check to make there is no cross-threading of the bolt. Additionally, you could give the bar a wrap in a layer or two of fabric athletic tape.
