XV95 Gas Furnaces Premium heating meets super efficiency
Delivering one of the highest efficiencies in the industry, the XV95, provides superior performance for the ultimate comfort experience. Trane XV95 features Efficient performance
The XV95 is rated with up to 96.7% AFUE and is Energy Star qualified.
Comfortable, even heating
Variable-speed fan motor adjusts speed to provide a consistent flow of warm, comfortable air with quiet operation.
Durable construction
Materials for all components are tested again and again for long-lasting performance and durability.
Cleaner, healthier indoor air
Add Trane CleanEffects™ to your system for advanced air filtration that removes more dust, pollen and other irritants from conditioned air for a cleaner, healthier, more comfortable home.
Trane XV95 specifics
Every Trane furnace is packed with high-quality components. Each helps ensure that time after time, your unit will provide total comfort your family can rely on. The XV95 includes: Variable-speed blower Two-stage gas heat provides greater fuel efficiency and better comfort control Heavy gauge, two-tone powder-painted cabinet Increased dehumidification with Comfort-R (™) mode Durable adaptive silicon Nitride hot surface igniter Multi-port, In-shot burners One-piece aluminized steel primary heat exchanger 24-volt Fuse protects Controls Insulated cabinet for quiet operation Convertible to horizontal left AL29-4C Stainless Steel secondary Heat Exchanger Cleanable filter with spring-loaded filter rack ERV, humidifier and air cleaner compatible
XV95 variable-speed, 2-stage upflow/horizontal furnace models **Model****Height (in.)****Width (in.)****Depth (in.)****Nominal Capacity Output (BTUH) Stage1/Stage2****ICS* AFUE** TUH2B060A9V3VA4017.52837,700/58,00096.7 TUH2B080A9V3VA4017.52849,500/76,00095.0 TUH2C100A9V4VA4021.02861,800/95,00095.0 TUH2D120A9V5VA4024.52874,500/114,70095.6
XV95 variable-speed, 2-stage downflow/horizontal furnace models **Model****Height (in.)****Width (in.)****Depth (in.)****Nominal Capacity Output (BTUH) Stage1/Stage2****ICS* AFUE** TDH2B060A9V3VA 4017.52837,000/57,00095.0 TDH2B080A9V3VA4017.52849,400/76,00095.0 TDH2C100A9V4VA4021.02861,800/95,00095.0 TDH2D120A9V5VA 4024.52874,000/114,00095.0
Trane XV95 limited warranty details
Beginning May 1 2009, Registered Limited Warranty terms are available if the product is registered within 60 days of installation. Registration can be completed either online at Trane.com or by calling 800-554-6413. Trane’s Registered Limited Warranty terms include: Lifetime limited warranty on heat exchanger 10 Year limited warranty on internal functional parts If the product is not registered within 60 days of installation Trane’s Base Limited Warranty terms will apply. Optional Extended Warranties available. Extended Warranties can pay for labor and other costs not covered by manufacturer’s limited warranty. Ask your dealer for full warranty information at time of purchase. Warranties are for residential use only, some exclusions may apply.
Compare Find Manual
Read-Only brochure
This product meets ENERGY STAR requirements when appropriate outdoor unit and coils are used. Ask your contractor for details.
