Heart Rate versus Power Training
Quick question, with a power meter on the bike do I ever need to worry about looking at my heart rate. If I have accurately calculated my FTP, why do I need to look at Heart Rate to train or race. Don’t I need to just look at power. Thanks.
Not sure. I use power exclusively to plan my workout. I do record heart rate data but use that after the fact to gauge my fitness, i.e., if over time I can reliably and consistently push a certain number of watts at a lower heart rate then I know I am fitter.
I’ve believe that HR is an indicator of intensity, just like power and speed.
Train by whatever method you choose but still record others and look for trends.
If you notice that your HR is at 200+ on a day you are putting out 180watts, you might have to make a decision weather to train or not.
If your HR is high on the bike during a race, you may be excited, pushed hard on the swim or maybe weather conditions had an effect on you.
My thoughts
jaretj
if you’ve accurately calculated your FTP - it still wouldn’t hurt to observe or monitor your HR, but i’m no coach. personally i retest using my pwr-tap every 6wks or so (depending on time of yr) to get a updated #s to determine my FTP -both PWR and HR @ threshold. however or whatever these numbers are i also carefully listen to my body (perceived exertion).
I use both info … when my body is on the edge of being too tired I gauge with the HR monitor…
For intervals and long rides I use power as a limiter ( hills … )
http://www.cruciblefitness.com/forum/topic.asp?TOPIC_ID=4208
