Heart Rate question (10)
A few things about heart rate chest straps that all seem to be mentioned already, but here in one place:
  • low battery power; the high to very-high measurements at any point during the workout
  • dry electrode straps; correct at first, but then high as movement causes bad contact. measurements settle down as you sweat
  • clothing interference; external “tapping” on the sensor can create false measurements
Advice for the chest strap HRM…
  • keep the strap and it’s metal studs rinsed after every workout
  • change the battery. replacements are cheap, and some only need a small phillips head screwdriver to get it done
  • use saliva to wet the electrodes, or electrode gel, or KY
  • keep the strap comfortably tight. if it’s too loose, the dry/poor contact problem is made worse by the strap moving (even very small amounts)
  • wear better fitting shirts :slight_smile: or at least something between a front zipper and the sensor to prevent tapping
Advice for the wearer…
  • relax! (your face, neck, shoulders, arms, hands)
I find that after my mind has been wandering for a while, and my heart rate is higher than expected, it’s because I’ve started tensing up.
