The one major symptom with fibromyalgia is "widespread pain" which I do not have. Also many of these other symptoms listed, as well as within other online resources I’ve checked out, I do not suffer from.
Although my symptoms and those of your friend are similar in nature I believe these I’ve mentioned above are key indicators for fibromyalgia.
I’m going to do some more research on this one however…thank you so much for sharing!!
Lack of pain may be indicative of myalgic encephalomyelitis.
You may want to compare your symptoms to myalgic encephalomyelitis: http://solvecfs.org/international-consensus-criteria-published-for-myalgic-encephalomyelitis/
…the central feature of ME under this definition is post-exertional neuroimmune exhaustion (PENE). To meet the criteria, an individual must have PENE, described in the following manner: “This cardinal feature is a pathological inability to produce sufficient energy on demand with prominent symptoms primarily in the neuroimmune regions.
“Characteristics are:
- Marked, rapid physical and/or cognitive fatigability in response to exertion, which may be minimal such as activities of daily living or simple mental tasks, can be debilitating and cause a relapse.
- Post-exertional symptom exacerbation: e.g. acute flu-like symptoms, pain and worsening of other symptoms.
- Post-exertional exhaustion may occur immediately after activity or be delayed by hours or days.
- Recovery period is prolonged, usually taking 24 hours or longer. A relapse can last days, weeks or longer.
- Low threshold of physical and mental fatigability (lack of stamina) results in a substantial reduction in pre-illness activity level.”
If these symptoms overlap with yours, I’d suggest talking with your naturopath about this docs research and treatment (as it helped me tremendously):
http://www.drmyhill.co.uk/wiki/CFS_-_The_Central_Cause:_Mitochondrial_Failure
Good luck.
When I saw the words “raking leaves,” it twigged a thought. Your symptoms sound eerily similar to those of Lyme disease. It could be a coincidence, given the time of the year in 2012, and a possibly indistinct memory of exactly what month you observed the symptoms.
Lyme disease masquerades symptoms of other maladies, which makes it so hard to diagnose. You have to get specific tests to find out about Lyme and Babesiosis.
Your symptoms sound very much like what I experienced almost 20 years ago. After a great year of great training and competition, my fitness just went off a cliff in a matter of weeks for no reason that could be diagnosed by traditional medicine or tests. Long story short, some people started using the word “chronic fatigue” which there really is no definitive test for. I don’t recall the exact name of the test I finally took, but it entailed taking a sample of my saliva 2-3 times per day at exact intervals the course of days to determine my adrenal function (hormone levels). The result of my test put my function at a 3 on scale of 10 which was equal to being age 70 (I was 36 at the time). It took me 2-3 of significantly reduced activity (no competition for sure) and being very sensitive to not putting my body under physical stress it couldn’t handle or another setback would occur (body has no ability to recover when it’s already struggling with much more than walking). Improvement came very slowly and it was still very up and down for 6-7 years… just kept making the mistake of doing more than my body could handle. It was in the 9th year that my body was finally able to start coping with normal types training (being able to recover was the turning point) and I started competing again in 2008. I’m not sure my body is able to reach 100% of perhaps what my potential once was, but at age 53 I’m looking at a goal of 55 minutes for our state TT championships next year (40k), so I’m very thankful for the health I’ve returned to. My fatigue was so extreme that I couldn’t walk up a flight of stairs without nearly fainting.
You look into adrenal fatigue?
Did 4 IMs and a Grand Canyon Rim 2 Rim as well in 4 years and the 5th year was really dragging . Could not figure what was wrong
Took a lot of tests & Adrenal Fatigue was eventually diagnosed. Went through the treatment protocol and came out the other side feeling as good as ever
AF is not a traditional medical situation so be prepared for some skepticism from MD’s
Worked for me; if was a placebo effect or not I feel 100% better.
Good Luck
out of curiosity, what was the AF treatment protocol?
i’m going to make a WAG that steroids have to be a large part.
