What is the best order to tighten the three headset bolts when tightening a headset? Whatever I do, I can not get mine completely solid.
I need to go take a week long course on bike maintenance! Thanks…
The mistake most people make is to not loosen the stem first. Loosen the 2 (usually) bolts on your stem so it can freely move side to side. Then, make sure the bottom of your fork is set in the headset well by loading the front wheel on the ground. Now, tighten the headset with the single compression bolt in the center of it. Then, realign and tighten the stem.
If there is still some play in the fork/headset - check your star nut/compression plug if carbon fork that it is tight in the steerer. Lastly, check to make sure the fork is setting square in the race. The headset itself is rarely the problem.
The steer tube may be to long.You may have to add a small spacer to the top of your stem or cut the steer.
Cullen
