I need to replace the headset on my bike. Trek’s website says the stock headseat is a Cane Creek IS 1-1/8" AHS (which I’m assuming is an integrated headset).
I don’t really understand the debate between integrated and non-integrated headsets - just basically looking for something that doesn’t cost to much and functions adequately.
As long as it fits inside, then it’s perfect. Cane Creek makes decent (not wonderful like a King headset) headset, uses decent bearings, and I think you will be fine.
If you have a 2100/2300 and use the Cane Creek 41.4mm insert diameter bearing, then pretty much all the integrated headsets will use a TH #873 bearing. FSA, Cane Creek, Tange, etc…
Same bearing.
I’m 99.9% certain that Trek, even Europe doesn’t use the “standard” Campagnolo 41.8/42.0 insert diam.
