Have you guys heard of tried WIN detergent?
They sent us some samples of this supposed “sports specific” laundry detergent. I was thinking the concept was a bit over the top. Pretty soon we’ll be pitching sports specific toilet paper.
Anyway.
I used the stuff (mostly because I ran out of Tide) and I was pretty impressed. It seems somehow “milder” and more foamy than regular laundry detergent.
The pitch is it gets the funky smell out, restores breathability in waterproof/breathable fabrics like Gore-Tex and restores wicking propoerties in base layer and wicking fabrics.
I can’t attest to that, but a windstopper fleece jacket I washed with it came out very fluffed-up afterward.
Anyway, the stuff is interesting and seems to work. I have an entire free bottle so I’m using it. Smells OK too.
I got some free samples. Seemed nice enough. I think it probably has a little more fragrance and maybe some fabric softener. I certainly don’t think it is worth the difference in price, since a regular sized tub of WIN costs as much as a “regular” detergent that gives you a ton more loads… It’d be interesting to see if someone who knows about these things can actually compare the contents of WIN vs. a standard detergent like ALL or Cheer.
I use the Penguin one (different product, same concept and marketing thrust) for all my workout gear. I do buy into the not blocking the pores argument but have no proof of this. I think it gets the sweat out better at the low temps you’re supposed to wash this stuff at too.
I figured out it was about .50 cents a load. I don’t know where that stacks up compared to Woolite or others.
Interestingly enough (or maybe not…) one of the original detergents recommended by W.L. Gore and Associates for Gore-Tex was Downy Flakes since they left no residue in the micro-pores of the waterproof/breathable fabrics.
Since then I think W.L. Gore & Associates have developed their own “Gore-Tex specific” sports detergent, I don’t remember what it’s called, but it ws expensive too.
Tom,
I actually bought it and it really gets rid of the “funk” that builds up in technical fabrics from running and biking. I love it and use it about every other load on my running and biking gear.
Mike
Interesting. I have seen this at a couple of running and cycling stores in my area and was wondering if it really worked. A real test would be an old piece of Patagonia Capeline top that I have to see if it removes the horrid smell :).
Assos and a bunch of others make a sport wash. Penguin also makes one, called sportwash or something. My opinion? It might extend your bib shorts a couple rides, but at what cost to your wallet?
For reference to your $0.50 a load:
http://www.amazon.com/All-Laundry-Detergent-Stainlifter-120-Load/dp/B000ENEPDG
$30 for 240 loads = $0.13 a load.
So WIN is 4 times the price (it’s actually 12.5 cents per load for what I posted). 4 times is a lot…
I personally like the castile-based soaps you can get from Seventh Generation. Totally biodegradable. Forget saving your bibshorts; save the environment…
I got a bottle of that stuff when it first came out, and over time it didn’t work. The only thing that has worked to get the funk out of the “dry fit” type clothing is Oxy Clean. works like a champ and you can buy it almost anywhere that sells laundry supplies.
Yep, bought a case recently from Amazon.com and must say that it works very well. Definitely makes the exercise clothes come out smelling fresh. I use it in a high-efficiency machine, FWIW.
I have used it a fair amount, several free samples and bought a bottle on a couple of occasions. I think that it works well and the stuff smells good but at least for me it is not worth the hassle of separate detergent/loads. No clue if it makes a differece in terms of clogging the holes etc but, like the gore tex example, I know on some of my ski stuff they recommend using powdered detergent as it supposedly effects it differently.
As has been mentioned it is a detergent that is designed to clean tech fabrics at the low temps you are supposed to wash them at. It really helps at getting the bad smells out of tech fabric that build up after awhile. There should be no fabric softener as that stuff kills tech fabrics.
GorTex you can almost do anything to and it will like it
you need to wash it every so often to get the dirt out from the fibers so it can go back to being water proof and breathable etc
you can even iron it or stick it into the dryer to restore it…
after a while though it will need a spray with some water repellent spray
Thread revival!
I’m in an executive MBA program and, lo and behold, WIN is my culmination group project. I’ll admit, I volunteered for it based on its target market, which is me.
Any more comments/users/ etc. would help me a ton. Also, target demographics data for our sport would help me as well. I’ll probably use any pithy quotes, so pith away.
I just reordered 4 bottles. I had many pieces of exercise gear that had the “funk”. I hated the fact that I had a great piece of gear in great condition, but it smelled like garbage after a workout. Before I knew what was going on, I actually threw out some perfectly good shirts because of the smell. I’d be ashamed to go into a store after a workout because it smelled so bad. Win made all my clothes fresh again. Great product.
I’ve also found that WIN works great. After Wisconsin this year, my clothes were soaked. They didn’t even begin to dry that night at the hotel and by the time I made it back to California, they stunk! I tried everything to get the smell out, I even threw out a shirt. I found WIN at the local sports store and gave it a try.It gets all of those funky smells out.
