Had my first chiro appt this morning
… to treat my IT band. Wow, that was a painful 15 minutes! They suck you right in too, going back tomorrow and 3 more times next week.
Hoping for a quick recovery so I can get running again! The pool bores me to tears and I could use a break from the trainer.
Best wishes on a Speedy recovery
Definitely one of those “Hurts So Good” moments. Everytime I go to my chiro, I feel the same way. It’s pretty painful during the session, but I feel so great after.
Adjustments I don’t find at all painful, but ART is a whole new ball game. My chiro does both.
I personally like chiros, but you do know what this thread will evolve into don’t you? :slight_smile:
It will turn into nothing but praise for my fellow chiros :wink:
I solved my IT band issue (related to cycling) by keeping my knees close to the top tube.
I will be honest, I’ve always been a little skeptical of chiro in general, but I’ll be the first to admit that it wasn’t really based on anything specific. In fact, my knowledge of what they do, their training, etc. was pretty slim.
I was recommended to this guy from a few people (one with the same problem and symptoms) so I figured it was worth a try before I make it worse.
Some of what he said/did was great, a couple things raised an eyebrow but I’m only interested in one thing - will it help?
And that I should know in a week or so when I run again… I’ll report back!
Iliotibial Band Syndrome (IT) is pain assoc. with a tight IT band as it passes over the hip and down to the knee. It has nothing to do with anything “out of place”. You may feel better as the chiro actually stretched your IT band for you, but it is not from a “subluxation” of the spine or your hip being “out of place”. Im wondering, have you been shown some stretches that you can do at home on your own and not have to go to the chiro for the same thing. If the chiro did not show you stretches then he/she may be more interested in you just coming back over and over again instead of arming you with techniques you can do to help future exacerbations and to get over this episode…(additional help can come from 1. ice, 2.stretches, 3.avoid laying on your side at nite, 4.using a pillow between your legs at nite if you lay on the other side, 5. antiinflammatories)…
I found that rolling my full body weight on a 8 inch foam roller was the best thing for my ITB problems. It is extremely painful to start but seemed to worked better than any stretch I had tried.
Nice way to get a massage without paying someone for the same thing!!!
OK,
I have a serious question that I want to ask any chiro’s out there.
I have been to a chiropractor once and didn’t like the experience. I did feel better after it (ITB issue). However, the sound of bones clicking and cracking (whether into place or out of place) is a little much for me.
That said, the science makes a lot of intuitive sense to me as a coach/personal trainer. I’ve palpated enough bony landmarks to know that very frequently they are not where they should be, and sometimes, even with aggressive stretching and corrective exercise it is hard to get a bone to re-align if it is ‘stuck’ against surrounding structures.
My major fear is that if a bone is ‘popped back’ into place repeatedly, will it become more lax and likely to pop out of place (subluxate) of its own accord? My fear seems backed up by those people who have a standing appointment with their chiro. Personally, my sense is that if the adjustment is not backed up by corrective exercise to change the resting lengths/tone of surrounding musculature, the client will be doomed to repeatedly falling out of alignment.
Would love to get others (particularly chiro’s) opinion on this.
Thanks in advance,
Alan
Sure is! I use it for Hams, Quads, calves even lower back. Not bad for $10.00!
Michael,
I think your view is a little simplistic. The SI joint is not a completely stable joint. Considering the muscles that connect to the ITB, namely the tensor fascia latae and the gluteals originate on the ilium, any movement of the SI is going to affect the tension on this band.
It makes a lot of sense that if the SI joint is in perfect alignment, then ITB issues are less likely to originate.
Regards,
Alan
The part of the appt I was least impressed with was that he seemed so busy I was really rushed in, beat up on (which was the good part) and rushed out. Didn’t get any time to talk about the injury. I told him I had been stretching to which he said keep doing it. I had also rolled once and maybe went too hard as it bruised up afterwards. He said I should hold off on the rolling to not overdo the treatment all at once.
The exercises he did I certainly could not do on my own and I wouldn’t trust an “untrained” person to help - that’d just risk a much worse injury.
I would let some PT’s I know at this one (by reading your question I can only assume you are a PT or OT or MD yourself).
But, just cause Illinois has some nuts does not mean the whole world does :slight_smile: I have seen the light as far as Chiro’s go (and need to see one in Canada).
Short answer b/c of time:
Too much adjusting can cause permanent ligament laxity. Frequency of 85+ adjustments/yr to the same vertebral joint will cause permanent deformation.
Chances of that happening in the ave. chiro office…rare. But you always have a few bozos out there.
Maybe longer answer later. Off to run.
How about this one…
I am a chiropractor.
I have a chronic IT band problem.
What do I do for it you may ask…
I have a very good friend/massage therapist/triathlon coach/personal trainer named Shawn Crotto who utilizes a bastardized version of ART and PNF stretching. At the first sign of the lateral knee pain, I increase the visit frequency to him. He spends about 1/2 an hour on it for two to three visits and I am good to go. Do I get adjusted for this problem? No, I do not. Thats not to say I do not keep my low back in alignment with regular adjustments though
That seems like an awful lot (almost 2x pw for a year)!
Are there any studies you can point me to that would help allay my fears?
Thanks,
Alan
I am also a Chiro and do very similar to what you do when IT Band acts up. The other thing I have found that has helped me is http://www.tpmassageball.com/quaddisfunction.php?id=20 I could not get rid of some issues I had no matter what I did I used this stuff and within a week months of problems were gone. May not work for everyone but it worked for me. For IT band it is similar to the foam roller.
