Guru Equipment Recommendations
Hello, I am about to take the plunge on a new Guru TriLite. I have it all specced out except two components. I am getting full DA10 on the bike, and have the option to go with FSA-K carbon compact cranks. I currently use a double Ultegra on my road bike, and have never needed a triple, so think I am fine with the non-compact Dura Ace. Would you go with the Dura Ace as the crankset, or are there some advantages to having the compact crankset on the race bike?
The second is very minor, but interested in thoughts on the VisionTech Aero lever vs the standard Dia Compe 188 levers. My LBS says he wouldn’t waste the extra money on the Aero levers…says the 188’s are tried and tested. However, I get stuck on the “new and cool” items. Just looking for a level set. Are the Aero worth the extra money?
Thanks in advance to any input!
BoilerBoy
They are a good value but make sure that that set of Dia Compe’s don’t buzz on you if the interior bolt isn’t tight…it’ll drive you nuts!
Good Luck.
I have a Guru (fine decision - you will love it). I also have the new DA10 and I really like the crank. I don’t think you need a compact variety.
I’m using the DC 188 levers on some old Profile CarbonX bars with no problems. But - if I was specing out a new bike and you like new and “cool” (like myself and most other tri geeks), I would get the vision tech leverrs. With that amount of money spent, what is another $75 or so. Like buying a car and not getting an options that you think you might want later. As for functionality: there is likely not one iota of difference as the old 188s are about as simple as they come (no return spring). Sounds like a great bike! Give it a great engine this Spring/Season and do it proud!
DA cranks are better … better shifting, better bearings (w/ the larger outboard BB), better chainrings. And, compact works fine in certain circujmstance, but regular size rings are better for most riding.
