today, my coach told me that i will run at the state qualifier meet on saurday. i’ll be the only freshman going from my school. i’ll be running the mile. oh yeah
good for you…good luck. What is your goal? Have you been winter training-shooting for an indoor peak and a sping outdoor peak?
college or hs? pr?
Right on! Go fast!
Have a great time.
“At 211 degrees, water is hot. At 212, it boils. And with boiling water comes steam. And steam can power a locomotive. One extra degree makes all the difference. And one extra degree of effort, in business and in life, seperates the good from the great. It’s your life. You are responsible for the results. It’s time to turn up the heat. To get what we’ve never had, we must do what we’ve never done. You are now aware. You now have a target for everything you do.” -212movie.com (check it out)"
BTW. That quote ignores the Delta heat of vaporization of water. Raising the water to 212 deg (100C) only requires 1 cal/gm (ml) of water per degree Celcius, but going from 212 deg (100C)water to 212 deg (100C) vapor requires another few hundred calories/gram of water (539Cal, if I recall). WAY more than it took to get from ice (ZeroC) to 212deg (100C)–5.39 times as much. (Just thought you might want to know.)
i
m assuming HS, as the college teams just had their first meets this weekend or last.
The NCAA doesn’t have STATE qualifiers. Defintely HS.
Good luck. What’re our times?
Junior and Community Colleges are often participate in state championships. I believe some Div I, II, and III schools do, as well.
Witness California:
http://athletics.lbcc.edu/athletichome/menstrack.cfm
http://www.cerritos.edu/hpea/athletics/sports/w_track/
BTW - your caps look appears broken.
