Went out yesterday to do my normal morning run and my Garmin Forerunner 305 could not maintain a GPS lock. It kept saying lost satellite reception. I thought maybe it was just my watch acting up. I’ve never had it do this before, I’ve ran this route hundreds of times without problem. SO, last night my wife goes out for her run using the Polar FT60 with the G1 GPS unit. She gets back and says… my GPS wouldn’t lock on.
Here’s my question, did anyone else notice problems yesterday with their GPS equipment not working? I saw this article earlier this year and just wonderd.
I had the same issue down here in Key West, FL w/ my 305. Started around 1045-1200 never had this issue before. I took it out last night and it was able to track.
My wife’s worked fine, but a couple of weeks ago her garmin showed that in the middle of her run she went almost 2000 miles/hr to a point about 6 miles away ran a few feet and then came back just as fast.
You’ve got to expect some weird stuff once in a while.
I remember a similar episode about 10 years ago (using an old venerable Garmin 45XL handheld unit) in Germany.
The sky was clear, satellite reception was perfect, but the unit was unable to compute a position fix for about 2 hours.
It turned out there had been a malfunction on one of the satellites, and a subsequent reconfiguration on other satellites, which affected GPS reception in some parts of Europe.
That outage was documented on the USCG GPS navigation center site.
I had 4 survey grade GPS base stations running for 12 hours yesterday in the Chicago area, I processed the data and saw nothing unusual. I have been using survey grade GPS equipment for about 15 years and I don’t think I have ever seen something that would affect the consumer grade stuff that we use for running. There are a lot of satellites up there, if something goes wrong with one of them, its immediately taken out of the system until its fixed.
Yup I was having problems with my 305 over the weekend also—same type of situation—open country roads that I ride ALL the time…seemed to just keep telling me Sat. lost…got annoying!! All seems better now though.
I was still having problems with my GPS. Being a numbers whore I finally called Garmin, they said I’ve must likely gotten some corrupt data (possibly while it was connected to the internet, I use Garmin Connect). The service tech said they’ve gotten several calls along the same line and that a hard reboot will fix it.
That’s funny, yesterday evening my Edge 705 had trouble acquiring the satellite lock. I waited several minutes and eventually had to start it over. It finally did get locked in and was fine from there but I can’t recall that ever happening before.
I lost 30 minutes in the middle of a hike yesterday evening. The map showed a straight line from the point where it stopped recording to where it picked up again.
