Good form and preventing swimmers shoulder
Hi, I’m a newbie and I’ve been watching the Freestyle Total Immersion DVD and trying to emulate that stroke when I swim. I’m definitely getting better but I feel like I’m not executing it exactly right because it results in a bit of shoulder pain after I’m done.
Anyone know of any photos or good descriptions that can help me prevent swimmers shoulder or make my form problem free???
I’m really trying to get the proper stroke down before I get into logging tons of laps…
Good question. Hope you get good answers.
I’ve seen/heard lots of debate over what’s right/wrong, good/bad. One thing I believe is that you want to use your larger muscles like your lats rather than strain the small ones in your shoulders. But I’m not sure how you do that.
One point of controversy is whether your arm (when extended forward, ready to catch/pull) should just pretty much go straight down from up there, or whether you should hold that elbow up, getting a vertical catch of water with your hand AND forearm, and then pull back/down. I’ve heard both sides of it, each saying that the other contributes to impingement.
A major cause of swimmer’s shoulder is poor recovery technique. Recover with a high elbow and draw the straightest line from your hand exit to your hand entry.
A high elbow/vertical catch with hand/forearm once you begin the stroke is, in my opinion, the most powerful method for swimming. This can create impingement, especially when pulling ‘hard,’ which is why folks need to 1) build up swim mileage slowly, 2) pay attention to what their body is doing/telling, 3) use paddles sparingly until strength in the lats/shoulders is adequate to handle the pressure, and 4) get some expert personal feedback sooner rather than later.
Supplemental exercises you can do to alleviate this issue are shoulder shrugs, lat pulldowns, tricep extensions, and stretch every day.
(disclaimer: I stay at holiday inn express and coach ‘swimming for triathletes’ 2x a week).
Agree with the above that recovery with high elbows is key in reducing shoulder strain. However, just as important, if not more important, is body rotation. Correct body rotation (I think TI emphasizes that) helps with a smoother recovery and helps generate more power for your stroke. If you don’t rotate your body you might be powering through the water with just your arms which is very inefficient and strenuous on your shoulders. Imagine swinging a golf club or baseball bat or throwing a football without rotating your hips and body. Probably will not work very well and will leave your arms/shoulders in pain.
That’s definitely a good point about using core strength/body rotation to diminish stress on the shoulders…
When everyone is talking about the recovery what comes out of the water first, the elbow or the hand? I’m not really visualizing that part…
Lets say you just finished taking a stroke with your right arm.
  1. Your body should be slightly rotated to the left
  2. Your hand should come out of the water first, or at least at the same time as your whole arm. That way you don’t lose any thrust from your stroke.
  3. As soon as your hand is out of the water, yank your elbow straight up into the air. Pretend that a string is tied to your elbow and is being pulled up.
  4. As your body starts rotating to the left in preparation for your next stroke, slowly move your arm with raised elbows forward. Don’t try and lead with your hand, but rather lead with the top of your elbow.
  5. As your body becomes flat with the water and starts rotating to the right side, gently slide your hand back into the water finger tips first (maintaining a high elbow).
  6. Continue rolling to your right side while now extending your right arm forward to the super-man position…
Obviously there are also some other things going on. But this should give you a general idea and visual.
Based on the shoulder problem that I just had, I was pulling too much at the top of the stroke by starting my stroke too early. Hand enters the water - then pause while your body moves over it (and your arm moves closer to a 45 degree angle) - then stroke. This way you miss that whole top part which really forces the shoulder.
Working on my rotation alone (before I knew about this arm pause) actually made my problem worse because I started stroking while laying on my side, arm way up above my head → too much pressure on my shoulder. Ouch.
PS - despite my fancy username, I’m no swimming expert, just a girl who loves to swim. Good luck!
