Golden cheetah and computrainer import help
appealing to the collective slowtwitch knowledge… searched around, found what I thought would work from the training peaks website but that still wouldn’t work.
I can’t seem to quite figure out how to import the data from the computrainer. I use the CS mode, preprogrammed with an erg file. After the ride, I changed the export options to toss 100 to decrease the size of the file. Then exported a comma delineated text file from the compCS folder with the same name as the programmed erg file. tried to import the text file into the new version of golden cheetah and i don’t get any data - not even the distance or the time.
when I open the text file I can see all of the data, including the “header” of the file which contains the original erg file.
for my FTP test I used the 3d mode on a flat course and somehow was able to import that file without a problem, subsequently, can’t get anything from cs to import.
any hints would be fantastic, thanks for your help
afternoon crowd?
http://groups.google.com/group/golden-cheetah-users/topics?start=
Hi,
Just spotted this post …
Computrainer / Ergvideo .TXT files support was added quite recently, you will need to be running the latest version (2.0).
You can download it here: http://www.goldencheetah.org/download.html
