Going from road riding to trainer?
Aside from the virtualpower aspect (no powermeter needed), it’s one of the few things in triathlon other than direct coaching than actually TRAINS you to get better,and appropriate to your ability. If you slack off, you see it right then and there.
I will add for any that are interested, that I just try veloreality’s free download software, and it lets you make workouts (very easily) and control a trainer like the Kickr (as well as virtualpower curves for fluid trainers) so you can actually get a lot of Trainerroad functionality for free - but you will miss all the premade workouts, and social features (like seeing how many people suffered through ISLAGIATT) and plans, so I think TR is still worth the money, but if you are like me and both need and want to do a block of all-self made workouts (and thus don’t need the library), you can do it for free with the veloreality download.
Link
http://veloreality.com/products/trainer-software/
Link
We are actually planning to release library of workouts and training plans.
Like others have said there is no power meter needed to get started. I do not have a power meter. The software will calculate what’s called “Virtual Power” base on the type of trainer you are using. Not sure how accurate this is compared to a real power meter but at least the readings are consistent so you can measure your progression. I started on Trainerroad during the beat testing back in late 2011(?). My first FTP test was a humbling 170. The last time I tested myself I was pushing 220, probably closer to 225 now. Still not a big number compared to some of these other crazy people but for being 56 years old I think I’m doing okay. I recently started the 1/2 ironman medium volume plan hoping to really push a bigger FTP by the time Oceanside 2015 rolls around.
BTW - DON’T get a fan - get a heater and embrace the suffering in true Sufferlandrian style!
That won’t make you faster.
Get Trainerroad. Get faster and never be bored again.
http://www.trainerroad.com/
It looks quite nice, but WOW, given the fact that power meters are very expensive, tack on an additional 100 bucks for a year and you’re adding a quite a bit of money to an already expensive endeavor.
Looks quite comprehensive though. :slight_smile:
It’s the cheapest highest bang for buck thing you can spend on triathlon improvement, actually. It’s not overpriced at all, and if you’re using virtualpower (no powermeter), it’s downright budget.
Powermeters though are indeed expensive.
^^^^This
I’m quite poor by triathlon standards so I thought that $10/month seemed pretty cheap in comparison to 1000 bucks for a power meter. Maybe maplesyrup doesn’t realize you don’t need a power meter with trainer road?
And I made huge strides by using TR with sufferfest for a few months. Its really a huge bang for your buck compared to just pedaling away with a video or even a workout. TR keeps you from cheating yourself. Its amazing how much an RPE of 7 feels 5 minutes in compared to 45 minutes in. No way you’d hold the same power without that damn red bar reminding you how far away you are.
Yes, I believe you caught me on that one. I only briefly skimmed the site but you don’t need a power meter? I have a trainer, I have a bike, what else do you need?
[quote MapleSyrupFast
You do not need one, correct. You need a speed/candence sensor that has ANT + capability. You’ll also want to check that TR actually supports the trainer you are using.
TR uses the speed and the resistance curve of your trainer to give you a virtual power number. Pretty much a meaningless number in the real world, but when used relative to your trainer road workouts it’s an excellent feedback tool, and can be used to gauge your improvements. When i say meaningless i mean 250watts on trainer road does NOT equal 250 watts with a real power meter. From my understanding, your actual wattage will be significantly less than what you see with virtual power.
But, it’s a great tool to keep you honest, improving, and to see results. You just have to make sure your external factors are similar…primarily the air pressure in your tire, and the resistance you apply to the tire with your trainer.
–ITU Elite Athlete–
Whenever I get stuck inside on my trainer I always have to modify my workout no matter what. Most of the time I do intervals based on heart rate zones. The nice thing about being on a trainer is that you can control some factors that you can’t control on the open road, elevation for instance. Out on the road you, sometimes, have no control over how flat or hilly your course is. On a trainer you are guaranteed to be simulating a completely flat course. This allows for true efforts. You can focus on heart rate and change your intervals however it fits for you. It is also good for easy bike rides. You can keep your effort in check and make sure you don’t end up pushing too hard. I know they have a lot of podcasts and live videos about stuff like this on Triathlon Research. Here is the link: http://goo.gl/vftCMI
Of course it is always more fun to be out on the road but sometimes that isn’t an option so you have to make the most of it. Hope this helps!
Indoor ST pros -
I will still be doing my long rides on the weekends on the road.
X2 but now darkness will force me inside for my Tues and Thurs evening rides.
So for me too, the trainer it is. Have you figured out your strategy yet?
