Is this a 3rd or 4th gen? 3rd gens are usually good to maybe 100 rounds to break in and remove any grit, which can be done dry firing. I don’t have any experience with 4th generations. But gritty triggers was a common complaint that even trigger jobs couldn’t fix consistently. My guess is 400 rounds will get it good.
4th Gen. I am trying the 25 cent trigger job right now.
I did the 25 cent trigger mod today. Completely got rid of the “gritty” sound. I think it still needs some break-in, but, it is a huge difference. Unreal. Thanks!
EDIT TO ADD: I’m pretty excited about the fact that I can completely strip the Glock now. Surprisingly easy. Funny how intimidating it was to me, but, a couple hours of playing around and I have it committed to memory and can take apart every single part in short order. In addition to the polishing, I took everything apart and cleaned it out. I have about 1500 rounds through it (prior to this tinkering) and am amazed how much junk gets in everything.
Reminds me of my enlisted Army days where I could strip an M-16 and put it together blindfolded! ![]()
If you are interested in upgrading that trigger in your ar build check out the real Geissele stuff. I run the super 3-gun in mine and it is not comparable until you try it. So freaking crisp and fast.
Awesome. Let me know what you think of the lighter trigger, I’ve considered for my G27 but have never gotten around to ordering the parts.
The Vickers mag release, slide stop, and Glock OEM 3.5# trigger is what is inside my Glocks. Shoot the piss out of it and the trigger will smooth out.
I did some major stippling to fit my hand better.
Glocks are the most modular guns out there. With that said beyond caliber swapping I haven’t had much use. I did change the trigger and my first. But didn’t find much benefit in it and switched it back. Most other common minds are not practical for a lefty like me. The issue he’s running into with the trigger job on the generation 4 is common. I knew certified Glock armorer who had to work many times on a single gun to get the trigger right.
I was going to say the same. I recently read a book about Gaston Glock, who had no experience with firearm design before submitting the Glock 17 to the Austrian military. The book said Glock did not set out to make the perfect handgun. He set out to make a handgun that anyone and everyone could use and make perfect for his/her own needs. IMO, Glocks are one of the ugliest pistols on the market, but, Gaston achieved his goal.
I’ve never heard the part about making it perfect for each shooter’s own needs. I don’t really think that’s what Glocks are or ever have been about. They might be modular, but they’re still not really readily customizable, and they’re still less easy to improve upon. To wit: With that said beyond caliber swapping I haven’t had much use. I did change the trigger and my first. But didn’t find much benefit in it and switched it back. Most other common minds are not practical for a lefty like me.
The point to a Glock is that it’s unbelievably functional as-is. Right out of the box, it’s capable of being used effectively by most shooters, it’s ridiculously reliable, accurate enough, and durable like an anvil. Ugly is just a byproduct. (Maybe. It’s a lot of ugly to achieve by accident.)
You can customize anything, of course. Even an SKS, if you’re so inclined. But I think most of the mods are incremental, at best, and I still say that most mods to a Glock, or an SKS, pretty much miss the point of the gun.
But hell, it’s your gun. Do what you want with it. Some people put spoilers on Geos, whatever. ![]()
The only other mandatory change at least for a non-carry gun is the sights. A fiber front will significantly improve your accuracy at > 15 yards.
Ah, come on man! That’s a low blow to lump me in with that crowd! ;-p
Yes, I take that back. I swap the sights on all my pistols. I only put a tritium on my HD front sight. The rest are all combat steel.
This as well. Ameriglo Hackathorns are my personal favorites.
I watched the $.25 trigger job and I’m hearing you say “Break in” and “Remove grit” and think to myself “WTF!?”. Is this simply an issue of “Mass production cheap guns”? I watched the video and there’s next to zero question in my mind that the problem being experienced is due nearly entirely to shoddy parts. Some of those parts appear to be stamped, not deburred and just put into the gun. “Grit”? In a gun? Good god that’s simply putting parts together that haven’t been properly cleaned or deburred.
I looked at glock prices quick, keeping in mind I don’t buy guns and have no idea what they cost, and the one I looked at was 500-600$. I’m just wondering if one where 1000-1500$ but had decent parts in it if people would buy it. MAybe I’m anal but if I baought a product like that and took it apart and found grit, grit that probably came from either dirt or small metal shavings from piss poor deburring I’d be pissed.
~Matt
Traditionally break in means part get sufficient wear to the point they are very smooth vs out of the box. You have to remember that a gun is a series of independent moving parts, that may or may not act consistently depending on the quality of ammo. Glocks do not fail. What we are talking about is trigger feel which is a personal issue.
You, when you go the store, might try 4 different models and not be able to tell the difference in trigger. Me, I can instantly tell the difference between a glock, sig, 1911 trigger pull based on the reset alone. In fact, if I have been shooting a glock for a long period of time, I have a habit of not allowing a sig to reset before pulling the trigger. Not usually an issue working from a sig-glock-1911 since it goes from long trigger reset to shortest. You get that feel with enough trigger time so that when you move from one gun to another, you might detect a slight variance. Let’s not even talk about rifles. When shooting my precision rifle, I can feel my finger throb on the trigger with each beat of my heart, and have learned to time my shot between beats.
Glocks have had consistent triggers for nearly 25 years. Meaning if you picked up one, you picked up them all, every pull is the same. But that changed with the generation 4 for reason I never bothered to learn, since it is just easier for me to stick with gen 3.
Part of it may well have been the rush to get things to the market during gun scares. This often happens, hence why I only buy sig sauer guns used and those made in the 90’s. The joke used to be that Sig Sauer’s customer service sucked, but you never had to deal with it. Well after Obama first got elected, a lot of people had to deal with it.
Go buy a pair of Specialized S-Works Tri-Vent shoes for $400. Keep them in the box. Then wear them for the first time at an Ironman race. Tell me how it goes.
Go buy a Nike SHA/DO Elite J Series baseball glove for $499. Keep it in the box. Then wear it at your rec-league championship softball game. Tell me how it goes.
When you re-cable your shifters and/or breaks, ever have any issues? Ever have to adjust the cable tension after the cables stretch?
Nearly every high-performance mechanical item needs a break-in period.
When I say the trigger has a “gritty feel,” I guarantee you would never notice it. But, when you start really getting a feel for how these tools work and you go through thousands of rounds, you notice little things that can be tuned up. Wifie plays the piano, stops mid-song, bitches about a string, and adjusts it. I didn’t hear a damn thing out of tune. Well, she cannot notice the “gritty” trigger.
I’m not a fan of tritium sites except on the front. Interestingly, Hackathorn agrees. Just so I can see the front of the gun, in dimly lit area. If you are lining up 3 dots in the dark, how are you identifying a target properly? At least that is how I feel.
What your talking about in the above is “Fitting to the specific individual” not “Break in”. Mechanical items that are fit to another mechanical item do not need a “Break in period”. “Break in” is needed for parts that are not built to tight enough specification to properly meet the need of the application. What you’re calling “Break in” I call “Wearing out” and “Wearing out” is an uncontrolled process.
Look at the difference between “Break ins” of the engines from 40 years ago to the ones of today. Smaller to no needed break in period and almost entirely because of tighter tolerances and better materials. Take a precision built engine and for the most part there is no break in period. Sure you’ll need a “Break in” for a pair of shoes because the shoes were not made for YOUR feet. Every part of a mechanical item, if made to the proper tolerances and materials SHOULD be made to fit perfectly and function properly.
What I’m saying is that I completely get “Mass produced” and that it’s cheaper and probably 90% of people won’t notice, what I’m asking is there a market out there for “Premium” precision built guns? Would someone buy a gun for 1000-1500$ that was precision built vs one that was “Gritty” and needed a “Break in period” for 500$?
~Matt
Precisely why I go with Heinie straight-8’s on everything I own. Hate the 3-dot sight picture.
Absolutely. Look at Ed Brown, Wilson Combat for 1911s and Robar for glocks. Nearly every major manufacturer has a custom shop with a la carte services. You can easily spend 1-2k on such work.
Glocks are very utility weapons.
