Thanks, good stuff so far. I am intentionally thinking about GFT *because *it is a non-IMNA race. What I’d like to know more about are things like how did the run wear on you given so much repeat ground?
A: The run is mentally tough because you start running around the lake, do an out and back, then finish running first lap around lake, then do two more laps (without the out and back). With the out and back, the first lap is about 12 miles. Mentally you imagine the second one is going to be as long, but it’s not, it’s only about seven miles. The second one went so much faster than the first, that I was actually psyched for the last one. Also, it is difficult running along circular lake that is seven miles in circumference. The distance looks huge.
Did anyone feel a little lonely on the bike because of fewer people as compared to an IMNA event?
A: First lap is crowded with plenty of ID distance folks, and then, near end, the HID racers passing you. Some folks didn’t like having half racers speed by them, but I kinda liked having the ladies pass.
Second lap was more deserted, but always someone is sight.
I would imagine this would not be the case for the run, given the repeat loops. I also imagine most people finish in the dark. Is this an issue regarding the ability to see the road surface?
A: My last lap was in dark. They had some portable lights on road, but other areas were dark. No darker than IMF when I did that race. No big problem.
Is the swim a little more neighborly also due to fewer participants?
A: It should be, but I kept swimming into the bunch, duh, so I got hit a few times – worse than IMF in 03. But if I could just have swum straight, no problem.
How was the aid station support in general, and was the lack of water and early volunteers just a fluke this year due to the hurricane?
A: There were a few problems at aid stations, but generally ok. I had a good race despite the problems. The cause of the problems is being hotly debated on GFT forum. Perhaps the organizer will respond.
The more I think about it, the more I like the bike and run course.
HH
