Do you guys get nose bleeds often? I’ve been getting them once a week or so since March. I’m not sure if something is wrong with me or if the pollen in Georgia is killing me or if the pool is drying my nose out.
sometimes. I used to pretty bad as a kid. I do now when I travel a lot in a plane or its really dry out. Best thing I do that works is smear a little Vaseline in each nostril once or twice a day. seems to help a lot. you dont need to try and scratch your brain, just a little dab just inside, then squeeze your nose, and it will work its way around by itself.
Hello duganator99 and All,
You can get the blood vessels in you nose cauterized to fix nosebleeds.
It is a quick and relatively painless procedure.
:max_bytes(150000):strip_icc()/close-up-of-boy-with-bleeding-nose-644068401-5c1a57a246e0fb000180f9b6.jpg)
Sticking your finger up your nose can help stop the bleeding too.
(Don’t try this at home!)
