Am seriously considering a build with one of the inexpensive carbon frames from ebay via Asia. Some can be had for under $600 shipped and right now, that fits my budget. I’m still trying to figure out if the fit will work for me. My main question is…how do the strange top cap adjustable integrated seat posts work? Is there any adjustment up and down or do you have to cut the post and then clamp the top. If that’s the case, one better make sure the fit is spot on right?
Anyone have any personal experience with any of these frames? I’ve read several threads referencing them, but couldn’t find anything with search function where the seatposts were discussed. Have tried to contact the seller, but not getting a ton of real answers through the broken English.
The top cap typically offers several cm or adjustment (and there are often some shims you can place inside the cap to fill the air gap). You cut the seat mast a bit shorter than you need (~1cm) and you have limited adjustability around that range.
This is fine as long as you have no plans to significantly change your position.
One problem I see with an integrated seat post setup on a no-name bike is that if the clamp fails a few years from now, it will be hard to find replacement parts.
If I were to go inexpensive & no-name, I would choose a frame that relies on standard components (round seatpost clamp with a generic aero seatpost in this case)
It looks like the seat clamp is similar to the Scott Plasma. You need to cut the seatpost to get it to a size close to where it will fit you (of course, you err on the long side). From there, you have some adjustbility by moving the clap up and down within a range.
One of the issues with these frames is that it is nearly impossible to get the proper dimensions. They usually mention the TT lenght, but who knows how they took the measure (is it virtual, is it the real lenght of the TT???)
But I do like the matte black finish!!
Should’ve posted a graphic of the geometry. I know what you mean on the measurements. It is likely to vary slightly, but I think I can make it work. Like I said…still trying to see if I can fit the frame.
And yes…the matte black finish is sweet looking. Part of the reason I’m looking so hard at this particular frame. I can get a slightly different generic frame rebadged as Element Six and they’re fairly local to me, but it has the gloss finish and is a few hundred more. But I’m a sucker for a sweet matte black finish.
Do you have a diagram of the cross-section of the individual tubes? I’m just wondering if these companies have started making anything resembling a proper airfoil yet. I like the matte black as well. Please post pics if you do end up getting one.
I just sent a request for pictures or diagrams of cross sections of the tube. We’ll see. Not likely they will come up with anything, but who knows. I’m sure it’s not cutting edge aero and almost certainly not wind tunnel tested. It looks fast though. That’s important right? I’m most certianly a MOP, so saving a few seconds won’t affect my placement much.
One other thing I noticed is the seat bracket that attaches the saddle to the post seems to be missing on the pictures. Will double check that that is included. Surely that’s something that is proprietary to the seatpost cap?
Does anyone have experience with cutting carbon? I will likely have to cut the post and wasn’t sure what the process was. Cut with a regular hacksaw? I thought I remembered someone stating somewhere to put some masking tape around and then cut through the tape to prevent potential splintering. Might have been reference to cutting aero extensions.
if you are just MOP and don’t care about saving a few seconds why not just get a metal frame from a more known quantity vendor?
i shudder at the thought of a custom integrated seat tube.
integrated seat tubes in general are bad enough.
I’ve had a Felt S32 (stolen).
Would like to try something carbon to help with road vibration and this is about what I can spend right now.
Can I help it I think it looks really cool? I’m really digging the stealth look. I think most paint jobs on bikes are pretty ridiculous. IMHO the only thing that would make the P4’s finish would be if it were matte black.
I’ve had one good experience buying a no-name carbon frame (and no bad experiences).
I am not afraid of the seatpost either.
Yes, masking tape over the carbon and cut it with a hacksaw.
If you do get worried about the lack of parts/support/warranty you could consider this as an alternative. It’s still inexpensive and generic but it’s backed by the American importer. http://pedalforce.com/...4ad48cd749d026887920
I looked at the pedal force frame. Looks very similar to the Element Six frame and I would likely just get that since it has a similar warranty and I could pick up locally. Dunno why, but I’m just drawn to the matte black. The seatpost does concern me to a certian extent though (hence the thread). We’ll see…thinking about the Felt B16 and upgrading the components. My budget might not support that though. Decisions.
If your worried about the seatpost have you looked at the Token TT frame? I’m prett sure this is pretty much the exact same frame except for the different seat post design. This is the frame I’m looking to pick up once I figure out the right size. If your intrested in the Token frame, send me a note and I can give you the direct contact info for them. I’ve been testing out some 58mm carbon clinchers for Token so I correspond with them a few times a week.
Go ahead and PM me or post info for Token including prices. Nice looking frames, but like the matte finish. Any chance they can get me an unfinished frame? I promise to put red Token decals on it.
Do a search on ebay for carbon tt frame. You’ll find it. Only one with a matte finish. Fairly new seller, but good feedback so far. I still am waiting on answers to questions.
I just checked with my contact at Token and they are actually in the process of redesigning their catalog /product line which should be available the middle of August. New TT frame, wheels, etc so I’ll post more info when that is released.
…and the TT frame is available in different finishes as well, RAW, Matt Black,…
Sorry, new here and couldn’t figure out how to PM you.
Finally got around to e-mailing them for additional info/pricing, etc…we’ll see what they say. Thanks for the contact information.
No problem, I know they are sending me the new 2010 catalog on Monday which is supposed to have a decent amount of “upgrades”
