Pulling out a middle cog is a bad idea. The jump would be terrible. The same as going from 25 to 29. Depending on the hills I would think a 39/25 combo would be plenty. I am not the best climber and I have no issues with that combo
Throwing a 29 in there for a day ought to be fine if your derailleur can handle that size. I’ve pulled cogs out of the middle and it worked just fine. Where are you finding individual cogs for $10?
Chad
This is not your avg climb -brasstown bald - tour de georgia. I have been told it would be best to adjust my gearing or I will be walking up. I will only be using the 29T for the one day. I was not sure if I would have to make changes to derailer with a 29T cog.
I wanted to do that same thing and was advised against it. Campy has a 12-29 cogset, btw.
I switched my gearing to a compact crankset (50-36) and put a 12-27 in the rear and there is pretty much nothing I can’t climb.
You could put mountain bike gearing on if the 36-27 isn’t enough. But at that point, you should probably train a little more on the hills.
you may have to add a couple of links to your chain as well. What is the average and max grade? I did the death ride on my 39/25, average grade of 8% and max of 19-21%
It should work. Shimano rear road derailers are rated to 27 max but you can usually get them to run fine on bigger cogs. I’ve run mine on a 30. You might have to mess with the “B” tension screw (the one that goes against the hanger facing forward). You may also have to put a couple of links in your chain or else be very careful about not accidently using the big-big combo.
If you are running 9-speed, I’d pull out the 14. If 10-speed, pull out the 16.
I am sure glad I had my compact 34 with my 27 for the berkeley try last weekend. I would have been walking otherwise.
So, with my 50/34 compact and 12/27, I have yet to have a hill get me off my bike, but last sunday was sure close!!
i have heard (never tried it) that a mountain rear derr is compatable with STI road shifters. So you can run a mountain cassette if you throw on a mountain rear derr. So if you really wanted low gearing you could go that option.
Right on Gayley Way
Left on Stadium Rim Way
Left on Centennial Avenue
Right on Grizzly Peak Blvd.
Turn around at the Grizzly Peak Blvd. and Skyline Ave. corner
Left on Claremont Avenue
Right on Tanglewood Road (Tanglewood Road turns into Derby Street)
Right on Piedmont Avenue
Left on Bancroft Way
Right into Spieker Lane, at the Transition Area.
Is there ever a reason you would go big/big? The truth is, you probably shouldn’t go up more than four or five cogs in the big ring. It’s physically possible, of course, but the resulting chainline is horrible.
Chad
I’ve done BB with a 27 and some serious weaving, it’s tough but doable for sure. Mountain gearing and derailleur would make it a lot easier and would let you stress the chain less, but it is one hell of a climb no matter what gearing you use.
I’m not certain but I think that the last three gears (biggest) on a shimano 10 speed cassette are all one piece. So if you replace the big three you end up with a huge jump in the middle.
I am not familiar with what the compact cranks would do for me except help on the hills. I only have one bike and it is a tri bike. I am a big gear pusher and the 53/39 setup with 12/25 has suited me fine for every race I have ever done. Actually, brassbald aside, I was looking to go 12/23 as I like to push a big gear.
But this trip poses a problem for me and I was looking for an inexpensive way to make the climb a bit more palatable.
I could get a 50/34 compact crank, but I don’t know if I would have much use for it during the season.
