(gear + cadence = power) <> perception?
The lower the cadence, the bigger the burden on the muscles. The higher the cadence, the bigger the burden on the heart. If you ride at too low of a cadence the leg muscles will fail early, and that’s why ‘spinning’ tends to save the legs. So people with smaller muscle mass tend to have a higher cadence and people with larger (leg) muscles tend to have a lower cadence. Everyone lands at a different cadence b/c of this. Watching the Tour over the years is a great example of this. Drugs aside, some do great at a lower cadence (Ullrich) and some to great at a higher cadence (Armstrong, Contador). So to see your hr climb like that would be expected to some degree.
thank you.
i’ve used RPE, not a HR monitor, to gauge effort and i’ve spun so i could “save my legs”. this makes me think i had decent leg strength but lacked the fitness for my heart to keep up. my legs weren’t tired when i get off the bike but i was.
Don’t forget that the inertial load is lower on trainer than on the road and leads to lower freely chosen cadence.
I am much like you. However I train to get a higher cadence because I find it much easier to respond to changes to speed in a bike race. When TT headwind gusting it takes more out of me with the low cadence. It takes more energy to speed the pedals up in a low cadence for me. So when I TT i will start in a higher cadence and hold my selected watts. When my hr starts rising too high i actually shift into a bigger gear and slow my cadence but hold same wattage. So for me I can spin until tired then cadence down and recover some hr wise but if I get tired in low cadence I cant recover accept decreasing watts. I think that for me I tire out my fast twitch muscles then use my slowtwitch muscles or vice versa. I am sure somebody will come in here and say Bullhit but it works for me.
There’s no one right answer on cadence that applies to everyone. I run 6 CompuTrainers four times a week and see all types of athletes and cadences. One athlete is a natural and smooth 110 rpm and couldn’t spin at 75 to save his soul without stalling out and rocking so hard (260 FTP). Another athlete is quite comfortable at 75-80 and couldn’t spin 110 rpm without bouncing around so much she’d fall off the trainer (170 FTP). Another guy is happy at 90 rpm (300 FTP).
I believe there are constraints, however. Below 65 rpm, the strain on the joints can be considerable, especially at high wattages. Not such a good idea for us “over 60” folks. Above 110 rpm, similarly, there is a lot of muscle activity in relation to power per revolution.
You should be able to bump your max-comfort level cadence to 100 rpm or more fairly easily with several focused sessions. Cadence efficiency is about neurological firing patterns that can be learned and improved very quickly by your body, similar to the quick up front gains people see when starting weight lifting programs. Just do a load of intervals of 30s-5 minutes with varying cadences well above your comfort zone. Don’t worry about power just jam your legs around at a high RPE and above 110 rpm.
Anecdotally, I have focused on this high cadence and low cadence force efforts a lot so far this off season. My first efforts I could sustain 280 watts for 5 minutes at 110 rpm (HR @ 160 bpm) and now 5 weeks later of 1-2 sessions a week I can hold over 340 @ 120 rpm and lower RPE.
I think over cadence work is a really good way to put high stress on the aerobic system and improve efficiency at a lower TSS and strain than FTP or SS intervals. They are also a great way to tune the engine and improve power in the TT position close to key events.
Give it a go and report back.
here’s a report back for anyone interested.
i took the aggregate advice and added some high rpm (>110) to my warm up. i also added a one-hour high spin trainer ride. i was doing four days a week of focused intervals anyway, so a fifth day of spinning was a nice change of pace.
ten weeks later, my “most powerful” range has lifted from 75-80 to 80-85. i don’t know if that’s good or bad, but it does seem easier on the body. and my threshold went up about 30 watts, so that’s a happy thing. yay. biking is great. more biking is greater.
Dave
